Snapped another belt
Old Apr 17, 2003 | 09:19 PM
Shadow's Avatar
At least this one lasted 10 months and 12K miles before going. Did those Kevlar belts ever get made? This is starting to get frustrating. I barely got the car to limp home before the battery died and the car stalled. Also, last time the belt jumped a rib and shredded. This time the belt just snapped clean off, what could have caused this?
Old Apr 18, 2003 | 05:24 AM
ejj's Avatar
ejj
Re: Snapped another belt
incorrect tension?
Old Apr 18, 2003 | 06:15 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Alignment issues?
Old Apr 18, 2003 | 04:55 PM
JAY25's Avatar
well go figure we both had belt issues, we installed our blowers in Feb of 02 your belt shredded in Aug time frame and it lasted quite a while now, I was right about the pulley with rails, now theres another issue. And no it was not belt tension this time is something else. Until you install the new belt you wont be able to figure what happened this time. Take the blower to a shop and have them install the new 3.125 pulley in there for you and then you can go from there for you. I dont have a bench vise, I do how ever have impact tools but for what is no use with out the vise. and you also need to get another bolt from vortech or something to replace the one thats stripped thats holding that 3.33.
so what are you going to do now? you taking it to the shop or are you going to remove the blower and have them remove the pulley only? go with a gator back belt and your going to need some work on that plate therefor your belt wont touch the plate.
Old Apr 18, 2003 | 05:36 PM
Shadow's Avatar
Re: Re: Snapped another belt
I'm going to pull the blower myself. You explained a lot to me, so I've got it down pretty much. Just have to go pick up a couple of those wrenches. My friend's shop is going to pull the bolt for me. I can get the new replacement bolt from Vortech? Or is that one of Stillen's parts? I hope Vortech. And I'm not using the 3.125, going with something a little smaller. So my friend's shop is going to do all the necessary machining to get it all to fit.
Where can I get the gator belts? Thanks.
Old Apr 18, 2003 | 08:23 PM
max'n out's Avatar
Kevelar belts ever get made?
Old Apr 18, 2003 | 09:36 PM
ejj's Avatar
ejj
Lots of people use gatorbacks. I have one, and the belt hopped off the pully by a rib, but didn't snap or shread. They're pretty strong.
Old Apr 18, 2003 | 09:47 PM
Shadow's Avatar
So where can I get the gatorback? Both belts that snapped on me were the NAPA/Gates belt. BTW, what belt size is used for the 2.87?
Old Apr 18, 2003 | 09:48 PM
max'n out's Avatar
060703 is the gates belt.
Gatorbacks are good, but still not kevlar.
Old Apr 18, 2003 | 09:49 PM
ejj's Avatar
ejj
I don't know what size belt is needed for a 2.87 so I can't help you there. I think I used a 0406710 (71" 6rib). Just replace the last 3 numbers with the length you had before (XX.X inches).
I got my belt from AutoZone. I assume most places sell them.
Old Apr 18, 2003 | 10:14 PM
Shadow's Avatar
Thanks. BTW, anyone know where I can get the hex bolt that holds the pulley onto the blower? Mine is stripped due to the original shop that installed it, idiots.
Old Apr 19, 2003 | 04:20 AM
JAY25's Avatar
get a gator back from Autozone, serious, thats who now carries Gatorback. Thats where I got all my belts from. I read lots of good things about them and they dont fray from the center like Gates does.
Old Apr 19, 2003 | 04:27 AM
JAY25's Avatar
Re: Re: Re: Snapped another belt
also get a very long slim screwdriver and get the oil return from the bottom, it is now a 5 min deal vice 45mins
Old Apr 21, 2003 | 08:15 AM
[maxi-overdose]'s Avatar
I think any stores specialized in nuts and bolts might have it...otherwise, you have to order it from stillen. Delio post the part no. in my thread in this forum. I started that thread in January.
mine's stripped too....I use a hex bolt instead.
Old Apr 21, 2003 | 08:22 AM
Shadow's Avatar
What size hex bolt did you use?
Old Apr 21, 2003 | 08:27 AM
correction : I use a regular bolt, not a hex bolt
a 12mm bolt, IIRC.
Old Apr 21, 2003 | 08:29 AM
LatinMax's Avatar
You can goto Metric & Multistandard Components Corp.
They have a location in Atlanta I believe. They can get you just about any bolt or fasner you need...they are awesome.
1725 Corprate Drive
Norcross, GA. 30093
770-935-9520
800-444-9560
fax 770-935-9511
If you don't still live in the Atlanta area let me know I will check and see if you are near any of there other locations.
They have locations in Chicago, New York, Dallas & Atlanta.
Old Apr 21, 2003 | 08:34 AM
Shadow's Avatar
Sweet, I live in Norcross, that address is about 10 minutes away.
Final question, hate to keep bugging you guys. But anyone know the thread count on the bolts? Thanks again.
1725 Corprate Drive
Norcross, GA. 30093
770-935-9520
800-444-9560
fax 770-935-9511
Old Apr 21, 2003 | 08:38 AM
LatinMax's Avatar
I think it is 12mm X 1.5 thread pitch. But I am not for sure.
When you go ask for a free cataloge. Its like 2" 3 ring binder.
Call and make sure that is there correct address.
05' MaximaMan
Oct 8, 2017 06:36 PM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
msellas
Sep 23, 2015 09:16 PM
