What is SAFC?
Old Apr 20, 2003 | 11:05 AM
CASS98SE's Avatar
What is SAFC?
I keep reading about this SAFC. It sounds like something I should have. I don't know what it is. I can only read back 4 pages..
Old Apr 20, 2003 | 04:51 PM
BigDogJonx's Avatar
http://www.apexi-usa.com/electronics_safc.asp
That will explain what it does.
Dixit
Old Apr 20, 2003 | 05:09 PM
CASS98SE's Avatar
Okay thanks, I understand now. Do you think I should buy it? I am going to have a egt guage, and FP... How much is it? Is it hard to use?
Old Apr 20, 2003 | 05:20 PM
BigDogJonx's Avatar
Do you have some form of boost? If not, then not really needed.
If you do, then yes, cause it will allow you to optimize the a/f ratio for maximum HP. It costs about $275 and is fairly simple to use.
You need to tune it on a wideband dyno.
Dixit
Old Apr 20, 2003 | 05:25 PM
CASS98SE's Avatar
Dixit
My s/c kit is in the mail. I don't have access to a dyno, so i guess i wont be getting this.
Old Apr 20, 2003 | 08:36 PM
Jer's Avatar
Jer
Btw Bigdog! I got some updated info from nissan... the s-afcII went in on Thursday night, and I did a bit of tuning at the track for my top end last night No traction to work with, but I got 0.1/0.2 and a couple of mph better in my 1/8th and 1/4 mile
Dixit
Old Apr 20, 2003 | 08:50 PM
BigDogJonx's Avatar
I thought you were having the worst time trying to get it to work and you were going to give up and sell it? Or do I got the wrong person?
Old Apr 20, 2003 | 10:34 PM
Jer's Avatar
Jer
I did and I was going to Fortunately I'm a stubborn bastard and couldn't give up
Old Apr 20, 2003 | 10:58 PM
BigDogJonx's Avatar
So what was it? I wanted to know how you eventually got it working, I remember working with you trying to get you working on it.
Dixit
Old Apr 20, 2003 | 11:15 PM
Jer's Avatar
Jer
Well the wires didn't match up ... Nissan Canada sent me an ECU diagram a little bit different from the ones that I had seen earlier on... it was my early build date.. for some reason it was just a little bit different (not sure why they couldn't/wouldn't give me a technical explanation) - I compared it to my friend's 2000 built in 08/2000 and it was different from my own.
I've never seen an automobile manuf do this... it's not worth the expense to change something mid-year... but as long as the car runs well and I'm not missing anything, I guess it doesn't worry me as much (maybe this is why my tranny is still alive - I got a rare early model version that is more beatable hehe).
Dixit
Old Apr 21, 2003 | 11:39 AM
Jer's Avatar
Jer
PS. I was too tired and didn't think about saying this earlier.. but thanks for the help (bigdog, maxi, etc)... appreciate it
Old Apr 21, 2003 | 04:41 PM
qnpark's Avatar
Dixit
u dont need a dyno to tune a safc. all u need is egt gauge. you could street tune it if u dont mind driving 100 mph. dyno tunning might be accurate but if u street tune it ur looking at 5 to 10 hp difference then a dyno.
Old Apr 21, 2003 | 05:42 PM
Jime's Avatar
I think a wideband O2 sensor is probably more accurate than doing it on a dyno. I don't believe the dyno loads the engine as hard as a wide open throttle run on the track.
Old Apr 21, 2003 | 06:35 PM
BigDogJonx's Avatar
Very true, but I have yet to see anyone here do it, plus its harder to make 3gear runs in an auto topping out at 125mph each time.
Dixit
Old Apr 21, 2003 | 10:56 PM
Jer's Avatar
Jer
Btw I'm still tinkering with the settings.. what did you folks set your AFC's to when it comes to low end (prior to boost)... I set it to 0% until 2000, then +1% at 2200/+2%@2800, then tinkered it a little bit on the rich side from there based on my wideband 02 dyno info (eventually going back down to a 3% increase by the time it's at 6600rpm - I was running much leaner until 4200rpm which was my primary concern/purpose for the afc).
I'm just sorta thinking that I shouldn't immediately feed an increase of 10% if the previous point was at zero...
Old Apr 22, 2003 | 06:30 AM
Stephen Max's Avatar
Do you have a recommendation for a wideband O2 sensor, Jime?
Old Apr 22, 2003 | 08:27 AM
Jime's Avatar
I don't Stephen, I have access to a very expensive one for testing so I am very lucky that way. My Son even gave me a bung and plug that I had welded on when I got my Y-Pipe installed and he has access to the wideband where he works.
Hopefully next week we will get a chance to try it out. He is just installing a new turbonetics turbo, etc etc etc for his DSM, so we are going to do it together.
I have looked at a few but don't think I want to spend the bucks for one at this time.
Jim
t6378tp
Aug 24, 2015 07:03 AM
ejj
Sep 19, 2003 11:07 PM
Max4Speed
Sep 16, 2003 12:39 PM
xHypex
Jul 15, 2003 07:24 AM
JAY25
Oct 21, 2002 03:15 PM
