Strut length question....
Old Apr 22, 2003 | 12:41 PM
shvelle's Avatar
I'll be replacing my front struts and putting Intrax springs on shortly. My question is this....., are Tokico, Koni, KY's, etc. the same length as our stock struts? I ask because I was considering buying Monroe Sensa-Trac stuts (there's a special on right now), but don't want to buy them if they'll just ride poorly.
Thanks guys.
Old Apr 22, 2003 | 12:43 PM
Lordrandall's Avatar
Yeah, they are all the same length.
Old Apr 22, 2003 | 12:54 PM
shvelle's Avatar
Thanks.
Next question then... Besides the name game, is there any reason most members aren't using name brand (but not performance name brand) struts?? Seems to me that an exceptionally large company, such as Monroe, would be able to build a strut that would perform just as well, if not better than Koni or Tokico?
Old Apr 22, 2003 | 12:58 PM
Matt93SE's Avatar
STFU n00b!
they valve them for ride comfort, NOT performance.
Old Apr 22, 2003 | 01:02 PM
shvelle's Avatar
Yeah...., that much I suspected. I guess what I really meant was - how significant would the real world difference between them be? I drive on very rough roads here.
Old Apr 22, 2003 | 01:24 PM
cneary812's Avatar
IMO if you are going to lower a car with lowering "performance" springs you should get performance struts. Reason being is that they are stiffer than the Monroes and the springs would not last as long otherwise, IMO of course.
Old Apr 22, 2003 | 01:27 PM
shvelle's Avatar
I'm lowering the car for visual appeal - not performance. It is a 4 door family sedan after all. However...., you make a very good point about the strut stiffness affecting the life of the springs. Thanks for your help and input guys.
Old Apr 22, 2003 | 01:57 PM
It won't really affect the life of the springs. However a normal strut/shock will not hold up as long if you match it with lowering springs.
Old Apr 22, 2003 | 09:53 PM
Matt93SE's Avatar
STFU n00b!
As randy said.. a soft strut will wear out even faster when paired with a stiff spring. higher spring rates require higher damping rates to keep the motion in check. otherwise you look like a flared and blared civic bouncing down the road.. yuck.
Old Apr 22, 2003 | 10:33 PM
kingrye's Avatar
thats me intrax plus oem struts
Pnjboyzz
Nov 16, 2015 12:27 PM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
