Wheel hop broke my car!!!
I took car to track Tues. and posted in 1/4 mile forum about it http://forums.maxima.org/showthread....readid=209354. On final run, I got severe wheel hop(wipers turned themselves on), but had heard that best runs were with hop, so I kept my foot in it and rode out the storm.
Now my car has a quiet "thunk" when I accelerate from stop. It is not very loud and can barely be felt. Noise is coming from front left suspension area.
By the way, this run was my slowest 60' (~2.45 seconds) and slowest quarter time and trap. I also got hop slamming second on all three runs. Car is 2k2 6spd.
I'm getting 2.3 60s with 0 wheel hop. I feel wheel hop is horrible for the car. Try a happy compromise between slipping the clutch and wheel spin. Wheel hop IMO is very bad for the drivetrain.
Re: Wheel hop broke my car!!!
Originally posted by SEturner
I took car to track Tues. and posted in 1/4 mile forum about it. On final run, I got severe wheel hop(wipers turned themselves on), but had heard that best runs were with hop, so I kept my foot in it and rode out the storm.
Originally posted by 2k2wannabe
just curious... how could you think that a tire breaking traction would make for a better time?
One of the regular posters on this site surmised that hop was better than just spinning because the car is gaining momentary traction instead of just simply spinning. He indicated his own personal bests were with hop. Also, I was racing a Mustang GT, and I just didn't want to give up!
In a FWD car, wheel hop is when the tire has a ton of grip in it (or the track sometimes), but when the car launches, alot of the weight transfers to the rear. Unfortunately it does not leave much to hold the tire on the pavement.
In my Monte, i don't have posi and i have really only hopped the tire once and it felt like the car was just going to fall apart. Wheel hop is BAD!
when you accelerate too hard the tires keep momentarily losing traction. they have traction then they lose it, they get some, then lose it, then get some...etc...its like the tires are hopping off the gound. this causes the car to shake and bounce.
Re: Re: Wheel hop broke my car!!!
Originally posted by PCGuRu2K
You probably broke your motor mounts at this point
because when i turn my car on it sounds like my engine is lose.
something is ****ed up
my car is ****
Re: Re: Re: Wheel hop broke my car!!!
Originally posted by BLKMAX005SPD
how would you go about fixing your motor mounts...
my car is ****
my car is ****
my car is ****
my car is ****
Most likely it's the rear bottom mount. Put the car on stands and crawl underneath. There is a support running lengthwise(front-to-rear) and it's mounted on that closer to the firewall. Use a crowbar or BIG azz screwdriver to pry on the support and a STRONG point on the engine. If you can wiggle the engine a little, you'll be able see if the rubber center part of the mount is torn with a flashlight. If that doesn't work, have a friend throttle the engine while you watch the mount. If it bangs metal-to-metal, you need a new one.
BTW, don't throw away the old mounts, you can POLY fill them for next time or if you can be without your car for several days, you can wait for them to cure and save you some money.
Re: Re: Re: Re: Wheel hop broke my car!!!
Originally posted by IceY2K1
Buy new ones from Nissan and GIVE ME YOUR OLD ONES!!!! Hehe. Just kidding. Call Dave Burnette at (888)254-6060 once you figure out which you need. Top mount ~$117, rear bottom ~$60, front ~$65, and the trans ~$73. These are old prices, so they may be different now.
my car is ****
my car is ****
Originally posted by Maxman2000
Tires woarm up and stick. Nut that's suposed to be done before taking off, Isn't it???
Short story, wheel hop is never good unless you're looking for a reason to replace a part.
Re: Re: Re: Re: Re: Re: Re: Wheel hop broke my car!!!
why not?
why not?
Really is.
Could also be the front left stabilizer link (Connects the front stabilizer bar to the control arm, has two ball joins that have a tendency to go), at least that's something that broke on my car.
about wheel hop and good times...
the first time I ever went to the track, my best ET was 14.9, and I had MAD wheel hop on that run.
it was like 70 out, and at 1000ft though....
a month later, it was 50 out, and I ran a 14.8 w/out wheelhop...
it sucks when it's doing it, feels like the whole car is going to break apart..thank God I didn't break anything.
good luck getting it fixed.
-vq
-vq
Hi, Forrest I did'nt know you were for real??
"One of the regular posters on this site surmised that hop was better than just spinning because the car is gaining momentary traction instead of just simply spinning. He indicated his own personal bests were with hop."
Stupid is as stupid does....
Steven Kusek with Frankencar was suppose to be manufacturing poly filled motor mounts for our 2K2's that would eliminate wheel hop. I was suppose to get one of the first sets but have not heard back from him.
Re: Hi, Forrest I did'nt know you were for real??
Lakersallday24
Jun 16, 2019 01:35 AM
trasmadean
Feb 1, 2017 08:20 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
bassmann
Aug 3, 2015 07:53 PM
