I'm Jumping To 2.87" Pulley.. What Should I Upgrade? More Boost!!!
Better have your injectors tested to make sure they can handle the additional fuel pressure you're going to need at high rpm. Or just get bigger injectors ala Matt and a few others.
unlike 4th gen, there are no bigger injectors for 5th gens
but 5th gen injectors have a higher volume than that of 4th gen.Danny: if you plan to use all 13psi from the 2.87. Do a compression test before you drop in that monster. or at least check spark plug condition. you are using 1 step colder, eh?
you've already got EGT, FP gauges...those will be enough for monitoring.
Originally posted by PCGuRu2K
I think I should be ok. I have about <50K on my motor and like <45K on my tranny. I've been running 1 step colder with teh 3.33" no pinging or knocking whatsoever.. You should I should drop to 2-Step? What are you using with you 2.87" setup? How's she running?
I changed to 1-step about 3000 miles ago. I dont think you will need 2 step.
my 2.87?
I am not using the whole 13psi of 2.87. I have it maxed at 10psi and I never tried to tighten the BOV. The car is running good.
my 2.87?
my 2.87?
I found most of the info that I needed.. But wasn't sure about the plugs. Ppl say to use 2-step cold plugs and decrease the gap to .005.. Anything else I'm missing?
Originally posted by max'n out
I say 1 step colder to be sure to fully ignite the fuel, my 2 steps got really fouled up. Gap them to .034
So with the 2.87" pulley you recomending that I run 1 Step Cold plugs and gapped to .034?
Danny : you got walked by a 350z??
My car weighs about 350lbs more then him so that's why it was pretty even matched
No he meant I really wanted to walk the guy.. I raced a friends 350Z the other day. All he had pretty much was just an injen intake. We raced from a role at about 40-120.. It was neck and neck the whole way. I guess after I switch to 2.87" I should be able to pull at least a few cars
whas next parashoots(SP) to stop ur car?
2.87 will yield about another 4 psi over the 3.33. that's 40 whp
his 350z is manual also?
Originally posted by GoldenGlory
so if i loosen it i reduce the amount of boost right?
and tighten it i increase the amount of boost?
so by loosen it ..i will increase boost?
ugh..
i wanna reduce for now till i get my 5 speed in
ugh..
ugh..
ugh..
not bad, not bad....I saw a auto 350z with injen dynoed at 230whp on my dyno day.
by the way ur freakin nutz danny
If you want to be special.. have someone custom fabricate a 2.00" supercharger pulley for you. Then we'll all get our kneepads and goggles out of the closet and will call you our GOD!
Sadly I doubt the S/C would last long, much less handle that very well
Nutz? nah... You have the 3.125.. You know I gotta be the big dawg in queens. I need to hold it down with the 2.87"
Originally posted by 20thdriven
What ever happened here... Did you go with the 2.87??? Was there a huge difference on the "butt dyno" to make it worth it? Anyone can answer this one, just doing a little research.
not only you get a lot of highend, but at low end, you get to 0psi a lot faster than a 3.33, around 2000 rpm.
from a 3.33, yes.
from a 3.33, yes.
