I'm Jumping To 2.87" Pulley.. What Should I Upgrade? More Boost!!!
Old May 1, 2003 | 09:29 AM
Stephen Max's Avatar
Better have your injectors tested to make sure they can handle the additional fuel pressure you're going to need at high rpm. Or just get bigger injectors ala Matt and a few others.
Old May 1, 2003 | 09:41 AM
max'n out's Avatar
THere fine.
Old May 1, 2003 | 09:58 AM
[maxi-overdose]'s Avatar
unlike 4th gen, there are no bigger injectors for 5th gens but 5th gen injectors have a higher volume than that of 4th gen.
Danny: if you plan to use all 13psi from the 2.87. Do a compression test before you drop in that monster. or at least check spark plug condition. you are using 1 step colder, eh?
you've already got EGT, FP gauges...those will be enough for monitoring.
Old May 1, 2003 | 10:35 AM
PCGuRu2K's Avatar
I think I should be ok. I have about <50K on my motor and like <45K on my tranny. I've been running 1 step colder with teh 3.33" no pinging or knocking whatsoever.. You should I should drop to 2-Step? What are you using with you 2.87" setup? How's she running?
Old May 1, 2003 | 10:37 AM
max'n out's Avatar
ONe thing to say if you are going to the 2.87 I'd get an intercooler, thats what I'm running.
Old May 1, 2003 | 12:32 PM
PCGuRu2K's Avatar
I found most of the info that I needed.. But wasn't sure about the plugs. Ppl say to use 2-step cold plugs and decrease the gap to .005.. Anything else I'm missing?
Old May 1, 2003 | 01:45 PM
Originally posted by PCGuRu2K
I think I should be ok. I have about &lt;50K on my motor and like &lt;45K on my tranny. I've been running 1 step colder with teh 3.33&quot; no pinging or knocking whatsoever.. You should I should drop to 2-Step? What are you using with you 2.87&quot; setup? How's she running?
I changed to 1-step about 3000 miles ago. I dont think you will need 2 step.
my 2.87? I am not using the whole 13psi of 2.87. I have it maxed at 10psi and I never tried to tighten the BOV. The car is running good.
Old May 1, 2003 | 02:01 PM
PCGuRu2K's Avatar
You didn't tighten the bov on purpose to release the boost more?
Old May 1, 2003 | 03:02 PM
max'n out's Avatar
I say 1 step colder to be sure to fully ignite the fuel, my 2 steps got really fouled up. Gap them to .034
Old May 1, 2003 | 05:33 PM
yup...to loose some boost. I dont think my car is ready for 13psi (esp my tranny) hehehehe
Old May 1, 2003 | 06:20 PM
PCGuRu2K's Avatar
So with the 2.87" pulley you recomending that I run 1 Step Cold plugs and gapped to .034?
Old May 1, 2003 | 06:38 PM
max'n out's Avatar
So with the 2.87&quot; pulley you recomending that I run 1 Step Cold plugs and gapped to .034?
Yes, thats where to start. Gap them .004 less for every 50whp, acuall result will vary when you hit the dyno, but thats where to start. .034 comes from a solid dyno based at 290. You can figure on at least having that and likely to have more, and from there you can make the adjustment.
Old May 2, 2003 | 12:24 AM
ToYLeT902's Avatar
JET Speed Lab
you really wanna walk that 350z huh?
Old May 2, 2003 | 03:08 AM
PCGuRu2K's Avatar
I don't know what your talking about. Tieing is not good..
Racing is bad
Old May 2, 2003 | 05:29 AM
Confused's Avatar
Permanent Maxima.org Resident
Boooooooost
Old May 2, 2003 | 05:53 AM
PCGuRu2K's Avatar
Originally posted by Confused
Boooooooost
Yeah.. The urge and hunger for more boost is too overwhelming
Old May 2, 2003 | 08:28 AM
Danny : you got walked by a 350z??
Old May 2, 2003 | 08:33 AM
PCGuRu2K's Avatar
No he meant I really wanted to walk the guy.. I raced a friends 350Z the other day. All he had pretty much was just an injen intake. We raced from a role at about 40-120.. It was neck and neck the whole way. I guess after I switch to 2.87" I should be able to pull at least a few cars My car weighs about 350lbs more then him so that's why it was pretty even matched
Old May 2, 2003 | 12:28 PM
GoldenGlory
so if the BOV is tighten more u get less boost.and if its loose u get more boost?
Old May 2, 2003 | 12:33 PM
GoldenGlory
No he meant I really wanted to walk the guy.. I raced a friends 350Z the other day. All he had pretty much was just an injen intake. We raced from a role at about 40-120.. It was neck and neck the whole way. I guess after I switch to 2.87&quot; I should be able to pull at least a few cars My car weighs about 350lbs more then him so that's why it was pretty even matched
by the way ur freakin nutz danny
whas next parashoots(SP) to stop ur car?
Old May 2, 2003 | 12:40 PM
I believe the opposite is true.
Old May 2, 2003 | 12:45 PM
GoldenGlory
so if i loosen it i reduce the amount of boost right?
and tighten it i increase the amount of boost?
Old May 2, 2003 | 12:57 PM
2.87 will yield about another 4 psi over the 3.33. that's 40 whp
his 350z is manual also?
yup...you loose it, you release the pressure faster.
Old May 2, 2003 | 01:31 PM
GoldenGlory
so by loosen it ..i will increase boost?
ugh..
i wanna reduce for now till i get my 5 speed in
Old May 2, 2003 | 01:35 PM
max'n out's Avatar
ugh..
You losten it it will begin to vent the boost, so you get less, course you could end up stalling the engine...try not getting on it.
Old May 2, 2003 | 01:57 PM
PCGuRu2K's Avatar
Yeap he's 3.5L 6Speed RWD about 3150lbs..
Old May 2, 2003 | 02:21 PM
not bad, not bad....I saw a auto 350z with injen dynoed at 230whp on my dyno day.
Old May 2, 2003 | 02:29 PM
PCGuRu2K's Avatar
ugh..
If you loosen your bov you will have rough idle and will stall out sometimes..
Old May 2, 2003 | 02:30 PM
PCGuRu2K's Avatar
230whp? Wow that's lil.. Don't those thing come 287hp at the crank...
Old May 2, 2003 | 02:31 PM
PCGuRu2K's Avatar
Nutz? nah... You have the 3.125.. You know I gotta be the big dawg in queens. I need to hold it down with the 2.87"
Old May 2, 2003 | 03:08 PM
GoldenGlory
Nutz? nah... You have the 3.125.. You know I gotta be the big dawg in queens. I need to hold it down with the 2.87&quot;
i thought i had a 3.25
tring to show off heh
Old May 3, 2003 | 12:55 AM
Jer's Avatar
Jer
If you want to be special.. have someone custom fabricate a 2.00" supercharger pulley for you. Then we'll all get our kneepads and goggles out of the closet and will call you our GOD!
Sadly I doubt the S/C would last long, much less handle that very well
Old Jun 29, 2003 | 12:36 PM
20thdriven's Avatar
What ever happened here... Did you go with the 2.87??? Was there a huge difference on the "butt dyno" to make it worth it? Anyone can answer this one, just doing a little research.
Old Jun 29, 2003 | 06:32 PM
Originally posted by 20thdriven
What ever happened here... Did you go with the 2.87??? Was there a huge difference on the &quot;butt dyno&quot; to make it worth it? Anyone can answer this one, just doing a little research.
from a 3.33, yes. not only you get a lot of highend, but at low end, you get to 0psi a lot faster than a 3.33, around 2000 rpm.
Old Jun 29, 2003 | 08:26 PM
PCGuRu2K's Avatar
Yeap.. That's exactly how it feels
Old Jun 29, 2003 | 10:55 PM
GoldenGlory
Danny's car is a monster!!!!!!!!!
Old Jun 29, 2003 | 10:58 PM
qnpark8282's Avatar
i get full boost at 3k .
Old Jun 29, 2003 | 10:59 PM
you raced that 350z again soon
Old Jun 29, 2003 | 11:02 PM
and you dont have to swap the pulley to get more boost, eh?
Old Jun 30, 2003 | 01:41 PM
Redmax's Avatar
Redlinemax Owner
whats the reason for colder plugs?
