I'm Jumping To 2.87" Pulley.. What Should I Upgrade? More Boost!!!
Originally posted by Redmax
whats the reason for colder plugs?
Originally posted by Stephen Max
Colder plugs have a better heat conduction path than hotter plugs, so they draw heat away from the combusting gases, resulting in lower EGT's and more resistance to detonation in boosted engines.
A colder plug will drop your HP if you're not seeing a large(r) amount of horsepower. Most of the SC'd guys stick with 1 step colder because we don't see max boost until redline. With a turbo you've got max boost at 3000rpm, which would be by far the better candidate for 2 steps colder.
2 steps colder and 3psi at 3000rpm is no good!
litch
123
Jan 4, 2024 07:01 PM
Need help
23
Oct 2, 2015 08:56 AM
