CV-JOINT PROBLEM - Car is apart NOW. HELP! SOS!
CV-JOINT PROBLEM - Car's up on jackstands. Please HELP!
Passenger-side CV-joint swap in progress:
Outer axle & joint were successfully removed from the hub assembly.
But. . .the carrier bearing (inner-side part held in by the three mounting bolts) won't come out, even though the bolts have been removed. The dern thing just won't budge.
How do you remove this f-er?
It's not sliding out & I've even used the side2side 'play' in the inner CV-joint to pull forcefully outward on the axle shaft, using it like a makeshift slide-hammer - but still, the carrier bearing won't budge.
I can't get a screwdriver between the mounting flange and the mating surface to pry it free, so what to do?
Please help - gettin' desperate here.
TIA,
-K-
PS: For those who have changed the entire passenger-side CV, did your carrier bearing slide out, or did you have the same trouble I'm having?
TIA,
-K-
Pull really really hard, seriously. I've done several nissans and none have been easy to pull (especially since I weigh 125lb). Try it with 2 people: 1 person pulling and another under the car, using a screwdriver as a prybar. There isn't anything else holding it in.
Jae
Jae
Originally posted by maximaseefu
i did mine a few months back, it literally jumped right out after I took out the 3 bolts. one other tip is to be careful of the seal when putting the new one in.
I'm going to try heating the carrier bearing bracket & another technique I found (tap outward at the bevelled edge of the inner CV-joint using a hammer & crobar to loosen - Found another thread last night where someone did this & was able to loosen it & remove the carrier bearing)
Thanks everyone, for the advice. Any other tips appreciated. I'll report back (hopefully w/ good news!)
UPDATE
Well, a combination of heating with a torch & whacking at the flange with a hammer finally opened up a gap.
From there, I was able to get a screwdriver and then a prybar between each of the bolt flanges & gradually work the carrier bearing assembly out of it's crusty tomb.
(As I suspected, there was a decent amount of rust and corrosion seizing it in there).
I'll be sure to sand the inside surface of the carrier bearing bracket so the install is A LOT easier than the removal.
Thanks again for all the help, guys.
Ok, back 'ta woyk 4 me.
-K-
EDIT - LAST UPDATE
Well, got the new raxles CV axle assembly in place and road tested. All is well, I'm glad to report.
My summary?
If you have a car that's over 5 yrs old or has been exposed to a lot of wet weather or wintery conditions, you might want to save the hassle & leave this job to a shop. I sacrificed a whole weekend to get this done, unfortunately. But it IS DONE! Woooooo hoooooo!
Btw, I did sand the corrosion off the inside of the C.B.S. bracket and to aid installation and potential removal in the future, applied a layer of all-purpose grease to this and the mating surface of the carrier bearing.
A special thanks to Marty at www.raxles.com who was very helpful & offered good support & information. I'll definitely deal with them again if need be.
Out.
-K-
EDIT - LAST UPDATE
My summary?
Out.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
Ray229Harris
Sep 16, 2015 08:16 PM
yat70458
Aug 3, 2015 01:16 PM
