Installation Instruction problems
Old May 13, 2003 | 06:11 AM
golzbra's Avatar
I was out on the Installation Instruction thread and many of the instruction guides that have external links do not work. I specifically noticed all the instructions linked to boostedmaximas.com don't link properly.
Who is responsible for ensure that these links are valid and working? Frustrated....
Thanks.
Old May 13, 2003 | 06:12 AM
NT2SHBBY
that would be good old Russ
Old May 13, 2003 | 06:18 AM
Donkey®'s Avatar
wat
What are you trying to install?
Old May 13, 2003 | 06:28 AM
golzbra's Avatar
I was out trying to the get the re-wire instructions for both the fog lights and side markers. I was able to get the instructions for the fogs, but ran into issues when trying to access boostedmaximas.com for the side markers.
I have had issues before out on this thread when I was browsing....there are other external links (besides boostedmaximas) not working. We really need to keep this updated to be effected.
Old May 13, 2003 | 06:45 AM
saxdogg's Avatar
those instruxtions are also linked from www.max-world.org
Old May 13, 2003 | 07:33 AM
cmr72's Avatar
Fog light re-wrie
Well if you have a 2K2 or 2K3, Russ' install instructions completely suck.
I forgot who posted the pic but you don't have to run any wires out of the relay box. Just cut the blue/silver-dash wire attached to the fog relay, and terminate the lead. Then tap that wire into the red/green-stripe wire under the tail-lamp relay. Presto. Fog lights work perfectly.
Old May 13, 2003 | 12:10 PM
golzbra's Avatar
Re: Fog light re-wrie
Do you think that holds true for the '01 Maxima's??
I'm a beginner at this and really don't want to f*ck sh*t up on my car, if I can help it....lol.
Old May 13, 2003 | 12:17 PM
cmr72's Avatar
Re: Re: Fog light re-wrie
It only makes sense that you should be able to tap the wire under the relay box, instead of running a wire to the headlight harness... You just need to find out which wire off of the tail light relay has 12v when the lights areturned on.
Old May 13, 2003 | 01:54 PM
golzbra's Avatar
Confused....why the wire off the 'tail light' relay??
doctorpullit
Oct 11, 2015 10:28 AM
Behuvius
Sep 14, 2015 01:49 PM
kirkhilles
Aug 8, 2015 10:53 AM
