cheap spark plugs
Old May 20, 2003 | 06:50 PM
JdoubleOe703's Avatar
teddibear703
cheap spark plugs
If you guys are planning on replacing your plugs soon, buy it here, NGK platnium
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2416141400
i just got a set for 37 for 6 plugs! thats almost half off!
Old May 20, 2003 | 07:07 PM
00MaxSE's Avatar
Pointy Elbows
Re: cheap spark plugs
Wow, that's a deal! But I'm gonna try the NGK copper plugs.
Old May 20, 2003 | 09:50 PM
[maxi-overdose]'s Avatar
Re: Re: cheap spark plugs
even cheaper....only 1.59 each. but you have to gap them frequently.
Old May 20, 2003 | 10:33 PM
01SE02SER's Avatar
Faster than a speeding bullet...
Yeah, I just got in on this deal too!
For those who are interested, here are the instructions for changing your spark plugs from the 2002 Maxima Electronic Service Manual:
Changing Spark Plugs
1. Remove intake manifold upper and lower, collectors.
2. Disconnect ignition coil harness connectors.
3. Loosen ignition coil fixing bolts and pull out coil from rocker cover.
4. Remove spark plugs with suitable spark plug wrench.
Spark plug (Platinum-tipped type):
Standard type - PLFR5A-11
Hot type - PLFR4A-11
Cold type - PLFR6A-11
Use standard type spark plug for normal condition.
The hot type spark plug is suitable when fouling may occur with the standard type spark plug such as:
- frequent engine starts
- low ambient temperatures
The cold type spark plug is suitable when spark knock may occur with the standard type spark plug such as:
- extended highway driving
- frequent high engine revolution
Gap (Nominal): 1.1 mm (0.043 in)
20 - 29 N·m (2.0 - 3.0 kg-m, 14 - 22 ft-lb)
Do not use a wire brush for cleaning.
If plug tip is covered with carbon, spark plug cleaner may be used.
Cleaner air pressure:
Less than 588 kPa (6 kg/cm2, 85 psi)
Cleaning time:
Less than 20 seconds
Checking and adjusting plug gap is not required.
By the way, what kind of tool do I use to adjust the gap? Also, why are the Nissan-recommended NGK spark plugs of a different model number than the usually-recommended PFR5G-11 plugs?
Peace.
Old May 21, 2003 | 05:37 AM
00MaxSE's Avatar
Pointy Elbows
Re: Re: Re: cheap spark plugs
I never heard of that. How often do we have to gap them?
Old May 21, 2003 | 08:24 AM
01SE02SER's Avatar
Nissan's 2002 Maxima Electronic Service Manual says:
"Checking and adjusting plug gap is not required."
Old May 21, 2003 | 09:02 AM
elmaximo's Avatar
That's because the manual refers to the platinum tipped plugs, not the copper (less expensive).
Old May 21, 2003 | 12:35 PM
y2kse's Avatar
I just purchased a set . . .
I was going to install NGK Iridium plugs, but $37.00 for a set of NGK Platinum plugs is too good a price to pass up. Thanks for the tip, teddibear703.
Old May 21, 2003 | 12:53 PM
Re: Re: Re: Re: cheap spark plugs
I would check them every 10,000 miles on my car.
coppers have shorter life too.
Pnjboyzz
Oct 7, 2015 10:47 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
