So much dealer work.
Old May 21, 2003 | 02:45 PM
Greek to the Max's Avatar
Guys, man, these guys are gunna do alot to my car.
They have to change the passenger side window motor, because the automatic up feature is not working.
They balanced all my wheels.
They are doing the ECU upgrade and changing the MAF sensor.
They are changing my Left drive shaft, bearing, control arm, strut assembly, cause they are not completely sure where the problem is.....
Just thought I'd mention it.
Old May 21, 2003 | 02:51 PM
maximadave's Avatar
detailerdaveb@gmail.com
damn!
Old May 21, 2003 | 02:53 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
2K3's have auto up passenger windows. That's it I'm selling! I want that!
So what problem are you having with your wheel/axle/bearing?
Old May 21, 2003 | 06:46 PM
releasedtruth's Avatar
rilla dope
My passenger window doesn't come up, only down. I have to help it back up. Sucks, I should have it fixed
Old May 21, 2003 | 08:39 PM
makes some moaning sound. When i first got the car it did that. Alignment was off too. So, they are not sure what it is, so they are changing the entire left side from what I gather.
Old May 21, 2003 | 09:54 PM
IceY2K1's Avatar
Under what driving conditions?
I get that on the passenger side front, especially when cold and turning.
Old May 21, 2003 | 11:13 PM
Tical6's Avatar
me too! whats up with that?
Old May 21, 2003 | 11:37 PM
limsandy's Avatar
My 2002 SE also can do that.
~limsandy
Old May 22, 2003 | 08:36 AM
For me, it does it when im turning in and out of parking lots that have curbs for example. My driveway....I was very lucky. When I went to teh dealer, I said please bring out the shop foreman, cause hes good. he came, and let me drive, which was a shock, other mechanics want to drive. So we found this muddy parking parking lot near a park. The perfect spot, all I did was let the car roll, and voila, the car was bouncing and it was making a symphany of noise from the left front end....Plus, my bearings started to tick when I start to accelerate.
Old May 22, 2003 | 08:38 AM
NT2SHBBY
auto up and down for both front windows
Old May 22, 2003 | 08:39 AM
kronnman's Avatar
~limsandy
Old May 22, 2003 | 08:42 AM
MaximaMan77's Avatar
Ice, the auto up is not from the key fob. It's from the switch in the door. Both front windows are auto up/down from either window switch in the car.
Old May 22, 2003 | 08:46 AM
Ues, great feature.
Old May 22, 2003 | 09:33 AM
billyman's Avatar
I wonder what us 2k owners can do to get the passenger window express up & down?
Old May 22, 2003 | 09:45 AM
ghostrider17's Avatar
Mine too....
Almost sounds like the Universal Joint (CV?) is going bad on the passenger side when turning left under power.
Like a metallic ticking or light grinding/clunking.
The bad part is that it's not BAD, and it's not easy to reproduce.
I had the thought that this was under the Control Arm TSB, but the dealer keeps telling me that mine was not affected.
I'm horrified that we're ALL having this problem.
Add this to the list of things they're going to be checking on my next visit.
If anyone else has any suggestions on what to do with this, i'm ALL ears!
gr
Old May 22, 2003 | 08:55 PM
Well, cv joint, control arm, bearing, driveshaft, strut and bushings can all make similar sounds. Ticking sounds on stop acceleration usual means bearings, or ticking when making a turn. Knocking sound when turning and accelerating usually means cv joint. Im pretty sure my problem is the bearings and strut itself. But, they siad they are changing the entire front left assembly. strut, arm, shaft.....oh well.
Old May 22, 2003 | 09:34 PM
IceY2K1's Avatar
Damn it!
I hope that's a switch control and not a SECU feature, so I can add that. I hate having to hold the button, I wish ALL the window had quick up/down.
mpbclutch33
Dec 26, 2015 11:11 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
