Redline oil 10w 30 or 10w40
Old May 22, 2003 | 10:02 AM
max'n out's Avatar
Cars only driven about 4 days a week at max...whata you guys think?
Old May 22, 2003 | 10:13 AM
MardiGrasMax's Avatar
10w30 is what I run year round so far, I may switch to 10x40 if I go to the track this summer. The RL 30 is as good as a dyno 40. I run the 10w30 for 6k with a 3 k filter change, oil tests are just fine so far.
Old May 22, 2003 | 10:22 AM
Jeff92se's Avatar
I'm needing a caw
Hmm whatever weights you guys chose to run, try to keep the viscosity ranges to a mininum. The larger the change, the more additives the maker has to put in to make the oil act like a ie... 5w when cold and 40 weight when warm etc... Which means as those additives wear out, the oil is not acting like a 5w anymore(or vice versa).
Old May 22, 2003 | 12:11 PM
Jer's Avatar
Jer
I still want to know how long till my motor blows up from 5w50
Hey, excess heat is excess heat...
Old May 22, 2003 | 12:40 PM
PCGuRu2K's Avatar
I've been running 5W30 since I had the blower.. Should there be any problems using that, orshould I switch over to 10W30?
Old May 22, 2003 | 02:05 PM
Jer's Avatar
Jer
Isn't 5w30 what the book tells you to use? I can't remember, but I'm almost 50% sure... anyways you're fine using 5w30 don't worry As long as the oil hasn't broken down that is - so just be good and treat your car to an oil change!
Old May 22, 2003 | 04:02 PM
max'n out's Avatar
10w 40 it is What place online sells it anybody know?
PS jer stop listining to nissan
Old May 22, 2003 | 04:11 PM
Jer's Avatar
Jer
I don't 5w50 baby.
Old May 22, 2003 | 08:55 PM
max'n out's Avatar
Sombody has to have come across this stuff online.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
