Changing tranny fluid to redline...???
Old May 29, 2003 | 08:14 AM
infinitiblast's Avatar
I'm going to be doing the tranny fluid change over to redline next week. I have a question though, they dont recommend you mixing for instance synthetic oil and regular oil as they dont mix....so is it ok to mix the redline tranny oil and whatever doesnt drain out of the system...since I will only be using the drain plug on the tranny?
Old May 29, 2003 | 08:39 AM
StygianMax's Avatar
Re: Changing tranny fluid to redline...???
I don't have a solid answer for you but that is what I ended up doing. Good luck with your drain bolt. I didn't win my battle with mine so I drained through the neutral position sensor. Here's my "how-to" (pics/text)
Old May 29, 2003 | 11:08 AM
Galager's Avatar
I just had mine changed to Redline. I asked the same question. Apparently, you don't flush manual trannies, so it's really your only option. I did it, and the Redline made a BIG difference. Cold shifting is much much better now.
Old May 29, 2003 | 11:17 AM
I guess here is my thought on all this. Notice all the people blowing a gear...some are blaming it on ACT clutches...well...I've noticed they are also running redline tranny fluid and if its not mixing well I bet the gears arent getting proper lubrication.
Old May 29, 2003 | 11:27 AM
StygianMax's Avatar
What do you suppose prevents two different tranny oils from "mixing well" and being effective to lubricate the gears? I figure the gears are spinning so fast that the oil gets kicked up all over in the tranny case. And as long as the density of each of the two fluids is relatively similar, they wouldn't separate quickly.
Only my $0.02.
Old May 29, 2003 | 11:29 AM
Jeff92se's Avatar
I'm needing a caw
Because he has no idea. The dino/synthetic lubs are compatible.
Only my $0.02.
Old May 29, 2003 | 11:59 AM
Ok well I was personally confused since they recommend not mixing synthetic and regular oil. Thanks for clearing it up.
Old May 29, 2003 | 01:04 PM
gr8max98's Avatar
Text on the back of the Redline MT-90 container: "compatible with petroleums and synthetics".
Old May 29, 2003 | 01:15 PM
Cool that clears it up for sure......if they say it on the bottle.
Old May 29, 2003 | 01:19 PM
Jeff92se's Avatar
I'm needing a caw
Question: Who is "they" and you don't have the bottle sitting there to read?
Old May 29, 2003 | 01:26 PM
rmb's Avatar
rmb
As "they" say it certainly doesn't hurt anything. But the perfectionist would drain again and refill in a few thousand miles. I changed mine at 30k, 60k and around 85k.
-RMB
Old May 29, 2003 | 01:49 PM
they is an elite group of people who know things that I dont.........
No I was refering to the Redline company.
Old May 29, 2003 | 01:53 PM
gr8max98's Avatar
Slightly OT--Who has been running Redline in their manual tranny for the longest period of time? How many miles?....just curious.
Jeff92se's Avatar
I'm needing a caw
I suggest you don't trust that particlar group of "they" much longer.
Old May 29, 2003 | 01:57 PM
I bet that would explain all the prbs I have...I wanted to thank jeff for all his smarta$$ comments in this thread. Anyone else like to thank jeff....jeff take a bow..everyone is clapping for you
Old May 29, 2003 | 02:02 PM
Jeff92se's Avatar
I'm needing a caw
Being right sure is a beotch.
Old May 29, 2003 | 02:12 PM
I felt like taking one too......
Old May 29, 2003 | 02:14 PM
Jeff92se's Avatar
I'm needing a caw
Old May 29, 2003 | 02:18 PM
StygianMax's Avatar
I understood you.
Old May 30, 2003 | 10:54 AM
95seMax's Avatar
i was wondering the same but didnt get as many responses when i posted a thread , i want to switch to redline fluid as well in my auto tranny and am planning to drain from underneath,
is anyone sure of how much fluid will come out if i just drain it from under pulling the drain plug?
Old May 30, 2003 | 11:02 AM
StygianMax's Avatar
Funny, the Haynes manual doesn't even estimate a quantity. They simply say the amount you should pour back should match what comes out.
Old May 31, 2003 | 01:35 PM
GTRMAX99's Avatar
I Had mine changed over to Redline synthetic at about 20000 miles. Two months later, time for a new tranny! I had the lube changed by a local performance shop. Maybe It's just coincidence, but I haven't used redline since.
Just my 2 cents.
Old May 31, 2003 | 01:59 PM
95seMax's Avatar
what year car did u have
so with 20, 000 miles you already needed a new tranny?
u have auto or manual?
Old May 31, 2003 | 02:05 PM
GTRMAX99's Avatar
It was actually replaced at about 32000. It's a 98 with a manual.
Old May 31, 2003 | 02:09 PM
StygianMax's Avatar
Was it under warranty still? I honestly don't think the Redline has anything to do with the tranny failure & it was just a coincidence in timing.
Old May 31, 2003 | 02:25 PM
JMAXIMA's Avatar
anyone know the difference between the OEM GL-4 and redline mt-90? they are both about the same price... but how do they compare?
Old May 31, 2003 | 06:03 PM
MilwMax5spd's Avatar
I changed my tranny fluid to Redline MT-90 in January, and I haven't noticed any difference in smoothness of shifts, no matter what the weather is like.
pktaske
May 6, 2016 07:49 AM
iamute
Sep 20, 2015 05:22 PM
Maxxx10
Sep 13, 2015 03:16 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
