Idle RPM
Old May 29, 2003 | 09:32 AM
silver99
Idle RPM
ok im adjusting my idle on my 99se auto.
wondering what RPM i should set it at
i messed it up when i pulled the ECU code and just set it to the lowest setting, all help appreciated. thanks
Old May 29, 2003 | 09:36 AM
97blackSE's Avatar
mine idles at a healthy 800...i would say somewhere round there
Old May 29, 2003 | 09:53 AM
hacim105's Avatar
Mine idles at 800 also. It use to idle at about 650, ever since I installed my MEVI now the idle is higher. I want to clean my throttle body though. When I took it off the old Intake manifold it was black but I didn't have any cleaner at the time. So hopefully once I clean that then my idle might go down.
How are you setting your idle by the way?
Old May 29, 2003 | 10:56 AM
njmaxseltd's Avatar
How was your idle changed when you pulled ECU codes?
Did you put that screw back to the center position?
Old May 29, 2003 | 12:27 PM
silver99
Guys, first off. thanks alot for your response
I changed the idle by turning the screw on the ecu. I think that this is specific to the 98-99 model but i might be wrong. When i reset the ecu the idle was too high (like 1100rpm) So I turned the screw and it lowered the RPM.
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
