Would warped rotors cause bad shaking under hard braking?
Old Jun 5, 2003 | 06:12 AM
Bmr4life's Avatar
Well thats what I think the problem is. Could be something else. My mom had her brake pads replaced about a year ago and ever since she's had bad shaking while braking. Now she's given me the car and I'm trying to get it into good running condition (ie, replace brakes, struts, cracked front bumper, and stereo). So if it is the rotors, how do I replace them or can I just have the trued by a shop or something? And if they can't be fixed, whats a better than OEM replacement that will fit with the stock wheels.
Old Jun 5, 2003 | 06:21 AM
largestal's Avatar
If the car has a few, more than 50K, miles on it - replace the rotors. Don't go cheap on brakes. If they fail-you are in BIG trubbles.
They might be able to be turned on a brake lathe and trued, but then again they might not.
Old Jun 5, 2003 | 06:27 AM
Bmr4life's Avatar
she has had the rotors replaced in the past, but neither of us can remember how many miles ago that was. (Car has 125k miles)
Well does anyone know a place that explain how I can remove/replace the rotors and a good replacement set? thanks again
Old Jun 5, 2003 | 06:28 AM
phenryiv1's Avatar
Mod her. Ate her.
Brembo rotors are the current rotor of chouce. Some prefer cross-drilled or slotted (or even dimple-drilled), but that can reduce life and lead to premature warping. Though those processes CAN, to some extent, slow brake fade and assist in heat transfer, if taken to the extreme of use the decreased mass and rigidity can lead to more severe warpage. Plus, it speeds up pad useage.
Just something to think about.
BTW- my rotors were warped 2 months ago from excessive braking and it resulted in loud braking from speed and a vibration and shaking. Replacing the rotors stopped the problem.
Old Jun 5, 2003 | 07:01 AM
wordjb's Avatar
Yes, If your steering wheel shakes while braking the most likely problem is that your rotors are warped. And yes Brembo rotors are a great replacement rotor, I recently changed my rotors to Brembo and I have been problem free for 2500 miles and counting.
Old Jun 5, 2003 | 07:24 AM
Bmr4life's Avatar
thanks for the replies guys. Looks like bremos it is then. Where can I get them for cheap but still get what ever warrenties there are for them.
Old Jun 5, 2003 | 07:34 AM
phenryiv1's Avatar
Mod her. Ate her.
Well, a lot of places on eBay sell them. irotors.com has them as well. I know that yuo cannot search, btu if you page back you will definately find something. If all else fails, PM me and I will run a search for you later today- I am a little busy now but I can do it later...
Old Jun 5, 2003 | 07:36 AM
Bmr4life's Avatar
thank you, i'll see if i can find it.
Old Jun 5, 2003 | 07:43 AM
maxfanfromohio's Avatar
Shiver me timbers.
I think the group deal is still going on for Brembos.
Old Jun 5, 2003 | 07:49 AM
Bmr4life's Avatar
oh great, how do i get to be a part of that.
Also, should I replace the front and rear rotors, or just the fronts?
Old Jun 5, 2003 | 08:23 AM
phenryiv1's Avatar
Mod her. Ate her.
I just replaced my fronts due to time constraints, but I will replace the rears when I get the time.
FYI- I just used some OEM rotors due to low funds...
Old Jun 5, 2003 | 08:32 AM
H.N.I.C.95's Avatar
A bad tire can also cause this problem.
Old Jun 5, 2003 | 08:38 AM
phenryiv1's Avatar
Mod her. Ate her.
usually that is speed-related (whether accellerating, decellerating, or maintaining a certain speed), not only in braking situations.
Old Jun 5, 2003 | 09:10 AM
StygianMax's Avatar
Lots of good instructions here: http://www.motorvate.ca/mvp.php/300 Note: these pics/instructions are just for accessing the front brakes/rotors. The rears are a little different. Post to ask if you need details for rears as well.
Old Jun 5, 2003 | 09:27 AM
Bmr4life's Avatar
thx a lot for the link and to everyone else who has replied.
Does anyone know off hand how much OEM rotors are because I can get blank bremos for only $80 a pair through the group deal. thanks again
also, of all the diff kind of rotors
xdrilled, slotted, dimpled and combos of these, which ones last the longest and allow the pads to last the longest as well?
BkGreen97
Apr 2, 2016 05:47 AM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
