anyone know how to program a 2nd remote?
Old Sep 14, 2000 | 04:28 PM
I programmed one remote on my '96 Maxima....can anyone tell me how to program a second one without losing the first?
I appreciate your help on this..........
Old Sep 14, 2000 | 06:57 PM
GarthG's Avatar
To program the second one, you have to start from the beginning again. Program the first one, and then unlock the doors, without opening the door, and lock them again. Make sure the key is in the ACC position and hit the lock button on the second remote. You can add up to four on your car. . . Hope this helps.
Old Sep 14, 2000 | 07:11 PM
Yep, it worked like a charm.......thanks so much for responding.
Old Sep 14, 2000 | 08:42 PM
GarthG's Avatar
No problem. . . I had the same problem the first time I tried it.
Old Sep 18, 2000 | 07:15 AM
humaras's Avatar
2nd remote
I was wondering if you might have bought a used remote and reprogrammed it. I was thinking about doing that since one of my remote is missing. Those old remotes can be reprogrammed right?
thanks =)
Old Sep 18, 2000 | 03:29 PM
GarthG's Avatar
You don't reprogram the remote. . . You just program the remote for the car. I think each has it's own frequency on it. You just have to get in the car and lock all the doors. You then stick the key in the ignition and pull it in and out like 6 times in 10 seconds. The front blinkers will flash and that means your system has been cleared of all previous remotes. You then turn the key to the ACC position and press the lock button on the remote. The blinkers will flash twice and that remote is programmed now for the car. Follow abouve instructions for adding a second remote, starting with unlocking the doors.
If you get another remote make sure it is for the generation car you have. 5th gen. remotes don't work with 4th gens. and vice versa. Hope this helps.
Old Sep 18, 2000 | 04:13 PM
Max I am's Avatar
are the other functions retained?
do all the functions of the remote still work like holding the unlock button to lower the windows and popping the trunk?
Old Sep 18, 2000 | 10:00 PM
GarthG's Avatar
Yeah, all functions of the remote are maintained. You lose nothing by addin more remores, just rememebr you have to program them all at the same time or they won't all work, even if you had them working before.
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
