V1 or V2 supa
Old Jun 18, 2003 | 11:36 PM
Playboycutie69
V1 or V2 supa
WHat is the difference between V1 and V2 supercharger?
Old Jun 19, 2003 | 12:12 AM
[maxi-overdose]'s Avatar
http://www.vortechsuperchargers.com/units/
Old Jun 24, 2003 | 10:15 PM
3000GT's Avatar
Re: V1 or V2 supa
since no one seems to know-- the v-1 has straight gears inside it. this makes it noisy. the v-2 has heli-cut gears(at an angle)so they mesh better. (less noise.) both units for the max are sc trim blowers. this means that the eff. hovers around 3.65-
Matt
Old Jun 25, 2003 | 06:01 AM
Stephen Max's Avatar
Re: Re: V1 or V2 supa
Matt
Also, the V2 produces about 1 psi more boost than the V1 for a given pulley size.
What do you mean by "the eff. hovers around 3.65-" ?
Old Jun 25, 2003 | 07:40 PM
3000GT's Avatar
Re: Re: Re: V1 or V2 supa
the effiency- when you use vortechs map to calculate pulley size.
Old Jun 26, 2003 | 05:59 AM
Re: Re: Re: Re: V1 or V2 supa
Oh, okay, I didn't recognize the 3.65 as a pulley size. But you're right, the center of the efficiency island is at a pressure ratio of 1.47 or so, which translates to a boost pressure of 7 psi - stock pulley size.
What I don't quite understand is the impeller rpm part. According to Vortech's impeller speed calculator, at 6500 rpm with the 3.6" pulley, the impeller speed should be up around 39000 rpm. But if you look at the compressor map, that a 39000 rpm impellor speed should give a pressure ratio of 1.8, or almost 12 psi of boost pressure. So does that mean 5 psi of boost pressure is lost due to friction in the intake piping on the way to the engine? Seems like a lot.
Old Jun 26, 2003 | 06:42 PM
3000GT's Avatar
Re: Re: Re: Re: Re: V1 or V2 supa
i dont know about the boost drop but the calculations also included the shift point--
3.65x6.5x6800(estimated shift point) then divide by pulley size. from what the tech told me, you want to run at the efficent rpm,s on the s/c. with a 3.6 pulley, the s/c is spinning at 44,814 rps.- obviously more room for a smaller pulley!! the v2 sc trim calculates with 3.65. the s trim is at 3.45-- the s trim delivers the same boost while only spinning at 42358 rpms.
Old Jun 27, 2003 | 05:25 AM
MardiGrasMax's Avatar
Yes the Maxima kit has substantial boost loss. Internal gearing on the V1 is lower than the V2, so you get more impeller speed from a given pulley on a V2 than a V1. V1's have proven to be more reliable than V2 kits, when stillen re designed them they tried to save money.
yongjun
Nov 14, 2000 06:20 PM
AntGVR4
Oct 10, 2000 11:29 AM
