Front end alignment question
Old Jun 19, 2003 | 10:03 AM
kingcarnage's Avatar
I tried searching, but came up empty handed.
there is 5/16 of an inch difference in width from front and back of tires. (toward toe in) also the car veers to the right when wheel is strait. Center position requires some force to maintain. Is torque steer involved, or just alignment?
Old Jun 19, 2003 | 10:19 AM
ghostmax's Avatar
Re: Front end alignment question
when was the last time your tires were rotated? are they cupped at all or worn?
could be the tires instead of alignment, probably not torque steer.
Old Jun 19, 2003 | 04:51 PM
Tim93se5sp's Avatar
Torque steer should really only occur when youre on the gas pretty good. Sounds like you need an alignment. Uneven tire wear may also be a factor, but that would have been caused by the car being out of alignment also.
Old Jun 20, 2003 | 08:40 AM
cmuehlenb's Avatar
It's proabaly alignment. Your toe in is probably OK. Camber makes the car pull to one side. Check visually to see if your front wheels look vertical. Improper toe make you steering wheel not straight. Your control arm bushings could be worn. It there any clunking on bumps?
boomerbrian
Nov 8, 2015 05:10 PM
JoshG
21
Sep 4, 2015 09:04 PM
official_style
Aug 29, 2015 10:10 AM
Samedi
Aug 12, 2015 01:54 AM
laparka66
Aug 6, 2015 09:36 AM
