cleaning throttle body
i'm goin to clean the throttle body, my question is "wat kind of spray should i use to clean it? would w40 be okay?"
n also, inside the throttle body there is a butterfly plate...can i lift that plate up to clean the plate n also clean watever is behind it?
sorry for all the question, but this is my first time doin it so i want to make sure i know wat i'm doin.
thanks
icheban26
thanks
icheban26
Re: cleaning throttle body
thanks
icheban26
thanks
icheban26
Re: Re: cleaning throttle body
Originally posted by pjalst
They sell "Throttle body cleaner" in auto parts stores. Use a toothbrush to clean the butterfly plate and inside the throttle body.
Originally posted by vsidesupratt1
Throttle body cleaner, at advanced auto parts.
now wish me luck
icheban26
thanks
icheban26
thanks
icheban26
that is oil/grease...you want to use a degreaser
look to the left of the tb opening...where the throttle cables connect...just push that and it'll open the butterfly up...then clean inside with a rag
use carb or throttble body cleaner at local car part store.. u can move the butterfly plate around.. clean all around it and dig as far in as you can with tooth brush cleaning brush ect. then use somethign to keep your butterfly valve open and let it dry for like an hour..(i sprayed in over half a can it left a pool in there..) then put everythigback and start your car. some people will telll you to start your car witha ll that tb cleaner stuff in there but i dont feel safe about letting that stuff burn through out my engine. think it can damage something.
gd stuff everyone
i will try to do this once the weather get better...i only wish a had a garage.
icheban26
gd stuff everyone
icheban26
like someone mentioned...be careful of that nozzle/strawit shoots off sometimes
after i cleaned it, i just started the car up...and let the fluid go through the rest of the TB and combustion chamber...
Originally posted by time2reup
also a good writeup on motorvate.com
thanks
icheban26
remove clips from the upper airbox.. remove teh hose clamp that connects the tb to the air intake piping. remove the 3 breather hoses that connect the the big plastic thing on the stock intake.. disconnect the 2 plug from the maf... then pull the whole thing off as 1 peice..this is good casue it gives you alot of room to work, and its easy to out back together.. hope this helps..
i still need to clean my throttle body... so all this information is gonna be helpful... just one problem... is it really easy as everyone says it is... i'm not too much of a mechanic or anythin'....
...j/k, but yeah...hopefully it'll start to make sense when the airbox is in front of me.thanks
icheban26
ahha.. when u look at it.it will come to you..just rememebr to use come common snese and dont take off more than you need..have fun man.. i got a wierd hissing sound after i cleaned my TB..souds like its comming fro near the injectors..anyoen else got that or know whats up?
There is a nice write up w/ pics on throttle body cleaning at http://www.motorvate.ca
another question...the silver clamp in the pic...do i just use force to slide it over or is there a better way to remove/loosen the clamp??? cuz i saw that clamp in my engine n its clamped pretty tight to the hose.
tia
icheban26
thanks
icheban26
icheban26
that is probably the last thing i want to hear
tia
icheban26
tia
icheban26
i finally got around cleaning my throttle body n changin the fuel filter. overall, the task was fairly simple...except that changin the fuel filter was kinda messy. so, i just want to thanks everyone who contributed to this thread n gave me adivce.
now i just hope i get better gas mileage than my current stingy 280miles/tank
thanks again!!!
icheban26
thanks again!!!
icheban26
How did you change the fuel filter? I tried that and couldn't get my hands into any decent position to get the screws. When I finally got a phillips head screwdriver onto the top screw, it wouldn't budge.
Assuming you did all the steps to shut down the fuel pump and depressurize the system, did you take the filter out of the bracket before you undid the screws? I can't even figure out how the dealer's mechanic would do it.
yes, pull the fuel filter out from the bracket...that way, at least u can have better access to the screws. but i would recommend u takin the whole OEM airbox, MAF piece out first...that way u can reach the fuel filter with no problem, n also cleanin the throttle body at the same time.
icheban 26
icheban 26
yeah, its nearly impossible to reach the fuel filter w/out removin air box n MAF piece. so thats y i follow the instruction at www.motorvate.ca for cleanin the throttle body (which requires u to remove the air box n MAF) n at the same time changin the fuel filter.
icheban26
icheban26
Changing the fuel filter and the PCV valve is a real b--ch. No need to remove anything but your fstb. You can easily remove canister from the upper hose and the lower hose. It is more difficult to unscrew from the canister because to tends to move.
it's a b--ch to replace but anyone can do it.
Originally posted by sblax2000
I have next to no mechanical skills but didn't have to remove the FSTB bar for the fuel filter replacement, what about the PCV valve, how easy is that to replace?
here it is, just go down the list. it's from the faq.
http://forums.maxima.org/showthread....5&pagenumber=6
220k+ A32
Sep 23, 2015 03:38 PM
97_GXE
Sep 15, 2015 06:47 AM
