KYB AGX installation
Just a quick question. Recently had my mechanic install some springs on my AGX's and he ended up putting the struts back on with one dial facing in and one dial facing out. Other than making it a bit more difficult to see one of the dials, is this going to present a problem?
Re: KYB AGX installation
Nope.. It will work fine.
Take the rear shock assembly out and install it with the dial facing inwards for easier access.
Shouldn't take you more then 15 min. to do. Make sure both wheels are off the ground when you do this.
Only 2 12mm nuts up top and one 17mm bolt on the bottom and it's done.
dvcamp
Sep 18, 2015 10:17 AM
