View Poll Results: MEVI screws, have they ever
Fall out with NO Loc-tite
23.81%
fall out WITH Loc-tite
9.52%
stayed on with NO Loc-tite
14.29%
havent checked yet
52.38%
Voters: 21. You may not vote on this poll
Poll - MEVI screws falling out
Old Jun 30, 2003 | 01:21 AM
Nismo's Avatar
To those with MEVIs and to those who had screws falling out heres a poll just to see the pattern if there is any
Old Jun 30, 2003 | 02:29 AM
Iron Lung's Avatar
Re: Poll - MEVI screws falling out
I pulled mine yesterday and thankfully they were still there. No loctite was used previously on the butterfly screws, but upon reassembly I used it.
Old Jun 30, 2003 | 05:56 AM
ejj's Avatar
ejj
Mine fell out.
Old Jun 30, 2003 | 06:45 AM
SLC98Max's Avatar
Mine fell out with no loc tite and I now am rebuilding the engine.
Old Jun 30, 2003 | 06:49 AM
ejj's Avatar
ejj
Rebuilding or replacing? Have to found the specific damage that was done?
Old Jun 30, 2003 | 07:28 AM
I30tMikeD's Avatar
No loc-tite and screws were still on tight. Will put lock loc-tite on soon though.
Old Jun 30, 2003 | 09:19 AM
Nismo's Avatar
so far nobody had them fall with Loc-tite so that a good thing.
Old Jun 30, 2003 | 11:48 AM
xHypex's Avatar
Why is there no option for stayed in with locktite :P I pulled the cover off of my collector today and my screws/butterflies are in good shape. The only puzzling thing to me is a puddle of oil I found.
It's not enough oil to be worried about, but I still didn't expect to see it.
http://www.imageevent.com/xhypex/cars/vicollector
-hype
Old Jun 30, 2003 | 12:26 PM
iansw's Avatar
Locktite - none fell out.
No reports of any of the ones I've sold falling out either.
Old Jun 30, 2003 | 12:55 PM
global_threat's Avatar
Good to hear You use the strongest color loctite?
Old Jun 30, 2003 | 01:27 PM
iansw's Avatar
I simply used Threadlocker Blue.
Old Jun 30, 2003 | 02:33 PM
Bags's Avatar
VG Ridah's Biatch Hoe
-hype
I checked mine and they are there and I am using thread locker RED
Also hyype, I do have about the same amount of oil as you and I spoke with jay25 and he has a small amount of oil as well.
I was concerned at first but no longer.
What do you make of it?
Old Jun 30, 2003 | 03:30 PM
JAY25's Avatar
yes I have a small puddle of oil on my manifold as well. I did not use loctite Use loctite and learn from everyones mistakes
Old Jun 30, 2003 | 04:37 PM
Nismo's Avatar
Im about to check my screws in about 20 min and Ill post what I see. Iilac also checked his but found somethign odd. we'll see
Old Jun 30, 2003 | 05:56 PM
Nismo's Avatar
ok, just got done checking mine out and they are still on there. I used threadlocker blue from the start. Didnt see any oil puddles yet either. I also indexed my screws by marking a line on the screw and on the plate with a sharpie marker, that way I can tell if they moved even a little bit the next time I inspect them.
Old Jun 30, 2003 | 07:02 PM
ejj's Avatar
ejj
I always assumed it was EGR crap...which would be perfectly normal.
Old Jun 30, 2003 | 07:42 PM
BSwithTF's Avatar
Used Loc-Tite Red. No missing screws or valves. I didn't use it at first but I thought I'd better and reassembled it with Loc-Tite before I installed it on the car. I'm REALLY glad I did!!!
Old Oct 4, 2005 | 05:01 PM
MDeezy's Avatar
wow way to bring up an old thread Nmex
Old Oct 4, 2005 | 06:07 PM
NmexMAX's Avatar
dot dot dot ...
Old Oct 5, 2005 | 01:46 AM
Nismo's Avatar
Damn I forgot I even made this thread.
Old Oct 5, 2005 | 03:25 AM
86maxima96's Avatar
I Broke OT
it's obvious the poll was a hit...
Old Feb 2, 2006 | 09:56 AM
motocross416's Avatar
well that was helpful, why don't you go find somewhere else to spam?
When I got my MEVI I checked all the screws and they were tight. I just had teh screws welded on just in case, it cost like $5 to have it done. The welding looks worse because of the burn't metal.
Old Feb 2, 2006 | 10:03 AM
MDeezy's Avatar
Originally Posted by motocross416
It does look bad becaused its burned but, your screws arent going anywhere. I remember the thread (and video) of an org member who's screw fell in the manifold and eventually took out the engine.
Old Feb 2, 2006 | 11:52 AM
illmortal's Avatar
Wow that some scarey ****... I wouldn't want a screw floating around my manifold then into my block!
How much are these Mevi manifolds?... I gotta get a rebuild kit for my engine and was thinkin of getting better performance parts to replace the stocks. I dont want to use soo much aftermarket, I know the Mevi comes off of Cefiro right?.. Or am I wrong? (My Nissan/Inifiti knowledge isn't all that well)
Old Feb 2, 2006 | 01:55 PM
MDeezy's Avatar
coutesy has one for sale $395.
Old Feb 2, 2006 | 03:32 PM
MaximaSE96's Avatar
Maxima Owner
plus extra parts to get it working
Old Feb 2, 2006 | 03:44 PM
Yep, it looks really bad, but its mostly because of the burns. When I got mine I keep reading all kinds of threads of screws falling out or losening, I believe some of them even had locktite. I still pull the top cover off every once in a while to inspect the valves and make sure everythings still okay in there
Old Feb 21, 2006 | 06:06 PM
1chewabacha1's Avatar
wow.... good thing this thread was brought back up.... I think I'm gonna weld mine this weekend. I've checked mine and it's all still on and tight. Used blue locktite on it when i first got it (8 months or so)
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
uttadms31
Sep 30, 2015 05:24 AM
