DIY Strut/Spring Install and Brake Install
Old Jun 30, 2003 | 05:18 PM
maxdick's Avatar
I'm on a tight budget, and my car needs new brakes soon. After 81K miles I'm thinking it's also time for some new struts/springs. I have heard that it costs $200 in labor for the struts, so that's getting pricey for me. I figure if I am replacing them I might as well go for aftermarket, I've heard good things about the Illuminas and H&R's.
So my question is, who on the forum has done this themselves? I've heard that a spring compressor is necessary, but how necessary is it? Would it be possible for two fairly strong guys to do it?
My other question is about stainless steel brake lines. I hate the "mushy" feel of my brakes, so I figure while I do the brakes I might get those. How much are they? I've heard they're pretty easy to install. The only ones I have found are on TireRack and they're $120 (GoodRidge), way too rich for my blood.
Old Jul 1, 2003 | 06:27 PM
maxdick's Avatar
anyone?
Old Jul 1, 2003 | 08:26 PM
Chunger's Avatar
My other car is a Hybrid
Rent a spring compressor and buy a service manual. If you have a good set of tools, it's not too bad. If you're not mechanically inclined, save up and pay someone to do it.
Old Jul 1, 2003 | 09:13 PM
Dev's Avatar
Dev
i hate seeing people waste money on simple things...just because they don't know whats actually involved
seriously, go to a couple suspension installation sites...and you'll see that the job is very easy...and will take about 4-5 hours for one person to do for the first time. after that it takes about 3-3.5 hours.
its really not as hard as it sounds
a spring compressor is necessary especially when putting the new springs back on (i installed ground controls so i didn't need them).
its as simple as this:
for the front: 2 lower bolts, 3 upper strut bolts
for the rear: one lower bolt, 2 upper strut bolts
compress the spring, loosen the screw holding the spring, compress the new spring, put it and all the other stock parts back in, tighting the screw holding the spring.
Old Jul 1, 2003 | 10:59 PM
maxdick's Avatar
Thanks man, I didn't think it was too hard. I'm fairly handy and I knew it was basically just a few nuts, I just never played around with the springs. Where can a dude rent a spring compressor? I'm from Long Island, close to Queens.. local info would be appreciated. Do most auto shops have them for rent? What about Home Depot? Thanks
Old Jul 21, 2003 | 04:05 PM
Black98Max's Avatar
you can rent a spring compressor at pep boys or autozone. I like the one that autozone rents out better.
Old Jul 21, 2003 | 04:09 PM
maximaah's Avatar
If you're at 81K you may also want to replace a few other items such as top strut mounts and dust boots, you can get these from KYB.
Old Jul 21, 2003 | 05:09 PM
stephenlc's Avatar
I am in the same situation, I am getting the boots and mounts, I want to do it myself buy my mom does not want me to do it. Someone will do my fronts for 125. I guess I have to do that.
Old Jul 21, 2003 | 05:14 PM
BBaker025's Avatar
I emailed you about this, but if you are interested I have some new SS brake lines for sale! Let me know if your interested!
Old Jul 21, 2003 | 05:51 PM
njmaxseltd's Avatar
Drive over the GW bridge about 15 minutes into New Jersey and I'll install your suspension for $100 bucks in about 1 & 1/2 hours while you wait.
Old Jul 21, 2003 | 05:56 PM
WOODYMAX98's Avatar
Does anyone have detailed instructions for this? I am going to try and do this next weekend. With GR-2 and H&R. Any pointers?
Old Jul 21, 2003 | 06:31 PM
bobjohnson's Avatar
Blazin......
Id DO THIS MAN. At that price id Pay Him to Do the job right the first time. this guy has credentials around here so that 100 bones hes offering is quite a "damn" good deal.
If i lived near ny i drive to have him work on my car.
Which i may do if i cant fix my rough idle soon.
hey nj, what shop you work for?
Old Jul 21, 2003 | 07:56 PM
maximaah's Avatar
Don't think there are many parts involved, just the bolts top & bottom. Probably a good time to invest in a Chilton's manual.
Any reason you chose H&R over Progress? I've decided to get GR2 vs. AGX but was planning to get Progress springs...
Old Jul 21, 2003 | 08:22 PM
maximaah's Avatar
BTW, I've found the best prices for KYB components at tirerack.com
Old Jul 21, 2003 | 08:54 PM
wrongway15's Avatar
autozone by me rents out 60+ free tools with a deposit required...check out your local one
Old Jul 21, 2003 | 09:01 PM
WOODYMAX98's Avatar
Do I need to buy any replacement bolts or anything? I would pay him to do it but I live by buffalo.
Old Jul 22, 2003 | 05:14 AM
MaxWolf's Avatar
I would take him up on this offer in a hearbeat. He has helped me out in many occasions. There are few, if any better than Tom. He is fast and could put a suspension together in his sleep.
Old Jul 22, 2003 | 05:25 AM
njmaxseltd's Avatar
Proline Body & Chassis
545 River Drive
Elmwood Park, NJ 07407
201-398-1512
It's my brothers shop. I'll be taking the position of Assistant Manager of the place in mid August.
Old Jul 22, 2003 | 07:00 AM
MaxWolf's Avatar
545 River Drive
201-398-1512
is it official?
Old Jul 22, 2003 | 08:44 AM
markargente's Avatar
njmax, would you guys also replace the bolts on my cat if i came by? So it would be 100 total for spring and struts? Also, how far from piscataway is the place? Im getting my springs and struts shortly. Thanks
Old Jul 22, 2003 | 09:57 AM
ohannon7's Avatar
A buddy and i just replaced my stock springs to progress this past weekend. I knew nothing about it and hes lowered a few cars. It was pretty easy i must say. I think i could do it myself if needed to. I do wish i replaced my strut boots while i had the operatunity b/c the factory ones are all broke and stuff. Kinda quickly this is what we did:
Jack up car, take wheels off.
On front end: Near brakes,take off the bolts that hold strut 17mm i think. take off 3bolts that hold strut under hood. Undo the silver clip thing and unclip the hose from near the brakes, take strut/spring combo out.
Rear: pull back the trunk liner near back seat, undo 3 small bolts.
Undo bolts near brakes that hold the strut. Pull out strut/spring combo.
To remove the spring from the strut: Compress spring, take bolt out of the top of the spring. Pull strut out. Uncompress. Do to all 4.
Then put it all back together. I kept stock struts w/ my progress springs.
Just make sure the spring sits exactly how the stock one did b/c there is a lil groove the end of the spring should rest in.
Sorry if thats vauge. I should of writtin it down while i was doing it. BTW i have a 99se if that makes a dif?
Old Jul 22, 2003 | 10:56 AM
maximaah's Avatar
Excellent! Only difference on older cars would be tossing the stock struts/shocks and putting the new ones in, plus replacing the top mounts.
Good idea on the boots, too. The boots on my '95 were just hanging in shreds so I cut them off, will replace when I redo my suspension.
Old Jul 22, 2003 | 11:45 AM
HuliganRS's Avatar
I would suggest an alignment after this job.
Old Jul 22, 2003 | 11:55 AM
njmaxseltd's Avatar
Originally posted by MaxWolf
is it official?
It sure is, check the OT forum for my Resignation thread.
You don't need to replace any bolts unless you strip or damage the threads. Check mapquest for the distance and directions, were right off Rt80. $100 includes everything.
You must have your alignment reset after any suspension work is done.
Old Jul 22, 2003 | 12:30 PM
ohannon7's Avatar
Can you estimate how much i should pay for an alignment. And would you suggest going to a local mechanic, or a pepboys type place, or the dealership?
I just lowered my car Friday and it does pull a lil to the left
Old Jul 22, 2003 | 12:56 PM
HuliganRS's Avatar
Go to shop with newer alignment machines!
I'd say $60 - $75
Rusty.
Old Jul 22, 2003 | 01:21 PM
Chino's Avatar
Nice! I wish I still lived in Manhattan (23rd & 9th), but then again I wouldn't own a car in the city. I'd hate to wake up in the middle of the night to move it for the street sweepers. Hehe, Tom you should move to Las Vegas, NV! Hehe...
Old Jul 22, 2003 | 01:56 PM
philpoe's Avatar
4 Maximas and counting
Does the install include dust boots and or bearings?
Can you also do the bushings?
In the case of springs/struts/bushings/boots, should an alignment be done right away, or let it settle for a week?
Old Jul 22, 2003 | 08:04 PM
njmaxseltd's Avatar
You have to supply the dust boots and new bearing if you want. If you reuse your old bearings I'll take them apart and regrease them for you. I will install the sway bar end link bushings for you as well. Again, you supply the bushings.
You can wait a week or you can do it immediately. I usually get my car aligned the day after I change my suspension.
Old Jul 23, 2003 | 11:17 AM
WOODYMAX98's Avatar
How would I know if I need to replace my bearings? My car has 60K on it.
Old Jul 23, 2003 | 11:26 AM
njmaxseltd's Avatar
your bearings should be ok, but I'd take them apart and regrease them if you take your suspension apart.
Old Jul 23, 2003 | 01:02 PM
JustMaxin96's Avatar
You don't have to put any grease on the outside of a new strut bearing right?
Old Jul 23, 2003 | 01:14 PM
Mishmosh's Avatar
Just curious, but what type of grease do you use. THe stock stuff seems to be very viscous high pressure stuff. MaxVQ has even said he doesn't recommend relubing because the thin grease one typically finds doesn't cut it long term.
Old Jul 23, 2003 | 06:41 PM
WOODYMAX98's Avatar
I just installed my two fornt struts in about 3 hours. I have never done anything like this before and it was not very hard. I rent spring compressors for like 8 dollars. I have two question before I put in the rears. How do the rear strut mounts go in? The little 1 inch things from KYB that are around 5 bucks. Are the fronts hard than the backs to put in? I will post pics when im done. Thanks
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
