Can feel liek a clack in sterring wheel when turning
Old Jul 13, 2003 | 04:47 PM
elcid's Avatar
Can feel like a click/clack in sterring wheel when turning
When turning at slow speeds I can feel a click/clack. And the other day reversing out of my garage I ahd the wheels turned slight as I reveresed,a dn then as I went over the end of our drive way I heard likea loud ping/clack Car drives fine, but sometimes I wonder if the wheels are going to fall of or soemthing, almost liek some play or something. I see no rips or tears in the cv boots, no grease anywhere. What could it be? Thanks in advance
Old Jul 25, 2003 | 02:43 PM
elcid's Avatar
Anybody? also the bar between the two rubber accordian things, I can jiggle it a bit? What does that mean? There are no tears in the rubber or anything but the metal bar/rod I can jiggle a bit....Is it busted? Can you email me since the forums page many times doesn't coem up for me. Thanks, I'm worried about driving and my wheels just fall off.
sergio3986@hotmail.com
Old Jul 25, 2003 | 06:43 PM
nismos14's Avatar
§è~® f®ÈÄk
im curious about it too
Old Jul 25, 2003 | 06:58 PM
njmaxseltd's Avatar
It sounds like worn out strut bearings causing spring noise due to binding.
Old Jul 25, 2003 | 07:31 PM
carnal_c30's Avatar
Former Sponsor
clock spring?
Old Jul 29, 2003 | 05:23 AM
elcid's Avatar
What about the metal rod between the two boots? Is that the tie rod? I can jiggle the rod on both sides (driver/passenger) Or si that something else?
Old Jul 29, 2003 | 05:59 AM
brizsblackmax's Avatar
lol its probably your cv joint
Old Jul 29, 2003 | 06:03 AM
njmaxseltd's Avatar
Those are you tie rod ends. If there loose, have your front end checked. They should be replaced and your alignment reset. Do you notice your car wonders on the highway or the steering has more play then normal? Those are all signs of loose tie rods.
elcid's Avatar
Really? Damn that sucks, on both sides, damn. I don't see any grease anywhere though. Man this sucks.
Old Jul 29, 2003 | 06:09 AM
elcid's Avatar
Ya there is play for sure and on the highway for sure. So it might just be the tie rods then, hopefully they're not too expensive....Any idea on $?? Thanks!!!
Old Jul 29, 2003 | 02:56 PM
JeffesonM's Avatar
living out of a maxima...
If it sounds like it's coming from the steering wheel and not within the car, take apart the steering column and look in there. Mine was making a cling-clang when I turned the wheel, and someties (although less noticible) when going over big bumps. There was a dampener that had come loose and was just hanging out.
trasmadean
Feb 1, 2017 08:20 PM
mrgooch
Sep 1, 2015 04:10 PM
Andy29
Aug 31, 2015 01:59 PM
jhontelj
Aug 17, 2015 04:07 AM
