upgrade wiring harness
Old Jul 30, 2003 | 01:24 PM
maxima2k2's Avatar
how difficult is it to upgrade the headlight harness? what has to be done? can you also upgrade the cornering light and tail light harnesses?
Old Jul 31, 2003 | 01:29 PM
RA030726's Avatar
I'm nutty for Nissans
i upgraded the headlight harness. I bought 2 spools of 12 gauge wire red and black, 2 relays, 2 fuse holders, 2 headlight sockets, a bunch of crimp terminals, wire loom, and electrical tape and zip ties. wait here is a link http://www.geocities.com/craigbraceg...htharness.html its not hard at all.my wat seems easier since i didnt go under the fender to mount the relays. There is no point in upgrading the other harnesses since the wattage is 5, 8, or 27 no 40/60 or 80/100.
Old Jul 31, 2003 | 05:28 PM
maxima2k2's Avatar
so your saying putting a bulb that is 5 more watts in the tail lights which stock is 3.8 wont matter at all right?
Old Jul 31, 2003 | 09:22 PM
RA030726's Avatar
what kind of bulb r u replacing? 1157 are a dual filament (8/27 watt) bulb for running lights and brake lights. 1156 are single filament for reverse and turn signal(27 watt) and 198 are single filament (5? watt)side marker lights. anyway the stock wires can handle 27 watts just fine. I used 50 watt 1156 with no problems.
Old Jul 31, 2003 | 10:05 PM
maxima2k2's Avatar
sorry i didnt make it clear, but what im saying is can the wiring harness handle 5-10 more watts for each 1156, 1157, and 194 bulb than its stock wattage, or will it melt the harness or housing in the future, if you leave the lights on all the time?
Old Jul 31, 2003 | 10:14 PM
RA030726's Avatar
hmm i would gess the fuses would burn b4 the stock wires would
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
Kingofmaximas24
Nov 12, 2015 04:40 PM
