Tial Wastegate
Dont you have a bolt right on the top of the TIAL wastegate? That adjusts the spring pressure to control if you want 7 or 8 or 9psi if you had a 7-9psi spring in there.
Now to remove the spring, there are I believe 6 bolts around the wastegate head, that removes the whole top and in there is a large spring you would change out. It almost takes two people to put it back on cause you need one who is putting mad weight on the top while the other gets in there with the bolts.
Dixit
Dixit
Nope Dixit, no adjuster screw here. It is the newer 38mm Tial wastegate. It has a 1/8" NPT threaded hole on the top for a vacuum source and another similar hole on the side for the other vacuum source. I just do not see an adjuster nut on it.....
I got a feeling that those are not adjusting wastegates. Ive hear those used alot with supras and other HP vehicals that always use boost controllers with them. I bet thats the reason.
Dixit
Dixit
Hmmm, but how do I know if it is at 7,8, or 9 psi? Thanks again Dixit.
BTW, here is an eBay link to an identical one I have: http://cgi.ebay.com/ebaymotors/ws/eB...tem=2426457185
SSR Engineering
94
May 24, 2004 07:19 AM
Ramius83
Aug 17, 2003 05:33 PM
Ramius83
Aug 11, 2003 02:26 PM
