Tial Wastegate
Old Aug 4, 2003 | 07:36 AM
Ramius83
Tial Wastegate
With looking at the Tial Wastegate before I install it, how the hell do you turn the spring up/down? I tried removing the allen head screws but YEAH RIGHT, those things are on there. Anyone know?
Old Aug 4, 2003 | 10:13 AM
BigDogJonx's Avatar
Dont you have a bolt right on the top of the TIAL wastegate? That adjusts the spring pressure to control if you want 7 or 8 or 9psi if you had a 7-9psi spring in there.
Now to remove the spring, there are I believe 6 bolts around the wastegate head, that removes the whole top and in there is a large spring you would change out. It almost takes two people to put it back on cause you need one who is putting mad weight on the top while the other gets in there with the bolts.
Dixit
Old Aug 4, 2003 | 12:03 PM
Ramius83
Nope Dixit, no adjuster screw here. It is the newer 38mm Tial wastegate. It has a 1/8" NPT threaded hole on the top for a vacuum source and another similar hole on the side for the other vacuum source. I just do not see an adjuster nut on it.....
Old Aug 4, 2003 | 01:16 PM
BigDogJonx's Avatar
I got a feeling that those are not adjusting wastegates. Ive hear those used alot with supras and other HP vehicals that always use boost controllers with them. I bet thats the reason.
Dixit
Old Aug 4, 2003 | 03:20 PM
Ramius83
Hmmm, but how do I know if it is at 7,8, or 9 psi? Thanks again Dixit.
BTW, here is an eBay link to an identical one I have: http://cgi.ebay.com/ebaymotors/ws/eB...tem=2426457185
Old Aug 4, 2003 | 03:49 PM
BigDogJonx's Avatar
From what im looking at it doesnt seem to be adjustable. Seems to be a fixed rate spring based on the spring you have in there. PS, you get my email about the calipers?
Dixit
Old Aug 4, 2003 | 04:51 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
just to add to what Dixit says, as far as I know, I'm 100% sure the 38mm are NOT adjustable w/o a form of BC, so no spring swapping like the 40mm!
Old Aug 4, 2003 | 07:28 PM
Ramius83
Well, that is fine. I already installed th Blitz ID Version 3 boost controller.........hehe.
Cotozic
Jun 28, 2017 08:01 PM
SSR Engineering
94
May 24, 2004 07:19 AM
Redmax
Mar 14, 2004 09:10 AM
Ramius83
Aug 17, 2003 05:33 PM
Ramius83
Aug 11, 2003 02:26 PM
