YIKES!! hte knocking noise is BACK!!
i was cleaning the IACV today and when i turned on the car again, i noticed that the whirling/knocking type noise is back in hte timing chain area. i got the TSB done a few weeks ago at the nissan dealer for 250 and now it seems as if hte noise is back. i called hte dealer and they said their so called machanics have to listen to it. what else could this noise be? bad steering pump, water pump
if it is hte timing chain tensioner again, the dealer should replace for free, correct?
If it turns out you're having problems with the same thing they worked on, then it should be under warranty since dealers usually warrant their repairs for 12 months/12,000 miles...at least at my local dealer. Show up with your receipt.
i read htat some people used thicker oil--15w 30, 20w 30/or 40........and hte noise went away. should i try that before a drive an hour to hte dealer? i ONLY have 86k miles
Could be almost any one thing or a combo of things. My whirling noise maker was the starter! I occasionally hear the timing chain rattle at startup too. Lately, another whirling sound has started so it may mean something else is failing.
CorollaULEV
30
Aug 9, 2021 08:11 PM
boomerbrian
Nov 8, 2015 05:10 PM
