How do you remove a window mount cell phone antenna?
I have an old one mounted to the rear glass of the car. It's broken, adn I dont use it. Is there a way to remove it, or is it glued with a special glue and it wont come off without risking breaking the window? Its just bugging me....
One good side shot with a hammer should knock it loose.
Disclaimer: I am not to be held responsible for any breakage of glass which may be directly associated to the actions mentioned in this post.
Originally posted by Albertt
Isn't there a wire leading into the car?
I installed cell phones, all you have to do is scrape off the inside and outside mounts with a putty knife. Then scrape off the old adhesive with a razor blade. As for the wire, you can cut it, stuff it, of remove it entirely. If the inside mount is on the defroaster wires be careful.
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
ef9
Sep 5, 2015 11:18 PM
