help guys, my belt shredded!
Old Aug 14, 2003 | 07:32 PM
hooktup98SE's Avatar
i got a front end alignment today and right when i left the shop, both my belts just shredded to pieces!!!! so now that i have to replace them, i am gonna upgrade the pulley.... if i go 3.25 or 3.125, will i still have to upgrade the fmu to a 8:1 disc, even with the 3.25? i know i have to with the 3.125, but not sure with the 3.25..... and also what belt sizes do i need? thanks
Old Aug 14, 2003 | 07:46 PM
Stephen Max's Avatar
Re: help guys, my belt shredded!
I have a 3.25" pulley, and I was definitely running a little lean with the 6:1. The 8:1 seems a little too rich, but not by too much.
Old Aug 14, 2003 | 08:58 PM
[maxi-overdose]'s Avatar
if you are running too rich with the 8:1....maybe you could test my theory few threads down there, "a cheap way to lower my fuel pressure"
but it is better to run rich than lean, stay with the 8:1 and get an S-AFC or just get the adjstable FMU.
belt size? have you checked the stickie in this forum, hooktup98SE?
Old Aug 15, 2003 | 05:58 AM
I have a safc, but I don't want to lean it out more than about 10% at high rpm without it being on a dyno.
By the way, Mardigrasmax went with a boost bleeder valve along with a 3:1 fmu, adjustable fpr and fields afc when he went to the 370 cc/min injectors. How he managed to juggle all that in getting to 12's is beyond me.
Old Aug 15, 2003 | 08:04 AM
maxxygrrl's Avatar
so if the 3.25" is running alittle rich, than is it safe to just go with the 3.125"? what do you all think is better? or should i say, safer.... thanks all... (this is hooktup98se by the way on someone else's account)
Old Aug 15, 2003 | 08:19 AM
Yeah, if I had to do it over from the beginning, I'd just go with the 3.125" pulley. Craig Mack is running a 3.125 and 8:1, and he thinks he is too rich. So you should be safe. I should mention I also have a variable intake, so I'm getting more air at high rpm. So a little rich for me with the 3.25 and 8:1 and mevi might be way rich for somebody with a 3.25, 8:1 and stock intake.
Old Aug 15, 2003 | 08:24 AM
thx Stephen...I just PM'ed him
Old Aug 15, 2003 | 08:27 AM
if your injectors can handle it....increase boost will make your car even more rich. the best way to know is to get a baseline dyno after you drop in the new pulley. have fun~ be careful when you remove those hex bolts and make sure to use some antiseize on the bolts when putting them back.
Old Aug 15, 2003 | 09:27 PM
96shogunmax's Avatar
I got a new 8:1 FMU disk and gasket if you are interested.
Old Aug 19, 2003 | 03:10 AM
20th maxstyle's Avatar
Do what I did, go to a turbo set up
Starrider
Dec 18, 2015 04:43 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
nbstriker10
Sep 4, 2015 04:26 PM
trungg86
Sep 4, 2015 04:58 AM
