??? on Tach
Old Aug 14, 2003 | 11:33 PM
DEVIOUS's Avatar
??? on Tach
O.k. guys need some help. my 98se 5spd tach is dead! I've tried swaping ECU's, tested the tach using the segment check in diagnosis mode and it turned out ok, used a meter to check the resistance on the gauge itself(with in specs), check for short between gauge and ecu(no short) any ideas?
Old Aug 15, 2003 | 06:29 AM
white95max's Avatar
Did you check the fuse?
Old Aug 15, 2003 | 06:37 AM
njmaxseltd's Avatar
You need to replace your speedo/tach head unit.
Old Aug 15, 2003 | 06:38 AM
nismos14's Avatar
§è~® f®ÈÄk
why did u replace the ecu? the guage cluster is probably problematic now, if everything else is working on it, get a replacement gauge cluster from someone here or on ebay and see if that works
Old Aug 15, 2003 | 01:40 PM
DEVIOUS's Avatar
What fuse?
I replaced the ecu due to there is no signal comming from the white/green wire.
swap the gauges huh.
maximaham
Aug 7, 2015 01:11 PM
Pat DiPersia
Jul 11, 2001 03:05 AM
sleeper
Jul 10, 2001 06:40 PM
sleeper
Jul 7, 2001 07:36 PM
jetmax
May 1, 2001 12:18 AM
