Are u happy with your gas mileage?
ever since i got my car i have been getting 240-280 miles per tank depending on how hard i drive. Sometimes all city, sometimes half and half...sometimes even all highway. I never get past 280ish. Even after changing fuel filter my miles still doesnt go past 280. I normally get 50 miles in before touching the Full line and then i get disappointed from then on (if i drive like a grand pepe)....
I just changed my 02 sensor (front heated)(as some of u may know) and i wasnt quite sure about my miles going up but i put a full tank of gas in yesterday and have consistently been driving hard, i mean shifting between 3.5 and 6 every gear depending on gear and who i'm racing. I normally get 50 miles before touching the F line when driving like a baby. Now i'm at 55 miles DRIVING REAL AGGRESSSIVE and i havent even touched the line yet!!! This so far shows that i am getting better gas mileage and i was too happy to wait for the tank to finish! WOOT
anyone else happy wit gas mileage?
Originally posted by EvilRoadsVictim
370-400ish. i drive like a granny (actually floored it 3 times in the past 2 weeks - yep i am counting).
i never floor it but i do wait till i get to high rpm's before i shifted...
what do u guys think is worst? shifting at high rpm's (5-6)or flooring it till u get to (3-5)
50/50 gives me around 320ish, mostly hwy gives me about 360ish. i guess it's alrite...
maintance history:
- change front O2 + knock 9 months ago
- oil change + filter change every 2,900 (DIY sty-o)
- 91 octane all time
- TB cleaned about 1 month ago
milage also improved throughout every new performance mods, which is also a plus rite there.
maintance history:
Originally posted by meccanoble
i just did a nice burn out 5 minutes ago
Used to get 280-310 miles for like 70% city, but now the tranny is rebuilt so hopefully it'll go up. I drive fast and floor it a lot
I'll replace the O2 sensors later on since the car has 96k and the O2 sensors are getting worn out. I need a new exhaust too and I know that'll increase the MPG
Originally posted by spiff56747
i get 360 per tank. wait that doesnt mean anything. wtf
mpg is not rocket-science, take the miles driven and divide it by the fuel consumed. There are lots of IQ tests on the web, perhaps there should be a big fat link to them at the top of the discussion. Be scary to see the results.
Again, I'm lost. Like you, I'm thinking WTF, a "tank" is the way that people on the forum calculate mpg? And we wonder why our education
personally i don't use the AC at all so that helps, especially in city traffic...
well the way i do it is i would fill up and then drive until the low gas light goes on. then drive some more around the area and pull up in the station on fumes, hit the 'B' trip computer and see how many miles i got...
Call us lazy but not stupid
i got 26.8mpg on my last tank at about 70% highway driving. during the winter when i was driving to school which was 10 min away, i had a fill up where i was only getting 17.3mpg. not warming the car up and the diff gas they give us in the winter sure does make a difference.
I too question how people come up with some of these numbers. In order to get reliable data you must fill the tank COMPLETELY, consume some fuel, track the miles traveled, then fill the tank completely. Simply divide miles by gallons put in the tank and you've got MPG. It doesn't matter if you use 1 gallon or 15 gallons, it works out the same. Using the car computer doesn't work because those devices are always off by a long shot especially the Nissan verisons.
Right now I'm getting about 23mpg of 80% city 20% highway in 100 degree temps and AC full blast. I consider that fairly decent because I reguarly romp the throttle above 5000rpms in 2nd and 3rd plus my 17s have much higher rolling resistance and the high temps cause the gas to vaporize when sitting in the heat while I'm at work.
Dave
Dave
What do you mean "how they come up with some of these numbers"? By having the trip odo start at zero and driving until I refill the tank.
I do calculate mileage by hand. I do not rely on the car's mileage calculator. I let it get to about 2 gallons left then refill it. I get about 380 MILES doing that...hence the MILES PER TANK reference. It's kind of assumed if you are talking MILES PER TANK that you're driving the car down to about the same amount of gas left, and 2 gallons fits that bill for me.
If someone posts a question about MILES PER TANK it's polite to answer their question using MILES PER TANK. If he asked about MILES PER GALLON I would have replied using MILES PER GALLON.
I can only see 2 or 3 people in this thread who need that IQ test that was posted earlier.
My 99 5spd mileage:
My commute used to be 50% hwy and 50% city (clogged hwy) and I got around 24-26 mpg and that was with pretty aggressive driving. Not bad considering my driving style and conditions.
Now my commute and driving is 100% city for the most part and it's down in the 22-23 mpg range, but now I drive like a granny (shift 5spd at around 3k most of the time, only occasional spurts above that to pass morons). Still pretty decent.
This past weekend I made a long-range trip of about 800 miles total, 100% of which was highway. I averaged 30.6 mpg on the way down, and 28.6 mpg on the way back up for an average of 29.6 mpg. Not bad considering a 99 5spd is only rated at 27 mpg highway. I was taking it easy and just cruising at 70-75 mph most of the time. Left it in 5th, even to pass people, and only once did I drop it down to 3rd to lay some smack down (on some idiot woman in an SUV throwing her weight around). When I got back I had 420 miles on the tank since the last fillup and it still had a 1/4 to go.
I had the tires cranked up to 36 psi for the long trip, so that helped a little too. Just had car washed, oil changed, and the air filter is still clean also.
If your mileage sucks, and I mean really sucks, particularly 4th gen's, either you drive like a complete maniac, or there is something wrong with your car. Even driving pretty hard in a lot of city traffic before, I still always got in the 24-26 mpg range. If you're below 20 mpg on a 4th Gen your knock sensor or some other sensor is probably blown and might not necessarily throw an SES light depending on what it is. 4th Gens blow knock sensors all the time and that doesn't throw an SES light. Mine is blown, but it's bypassed. My mileage would suck right now in city driving without the bypass resistor. Probably teens at best.
I had the tires cranked up to 36 psi for the long trip, so that helped a little too. Just had car washed, oil changed, and the air filter is still clean also.If your mileage sucks, and I mean really sucks, particularly 4th gen's, either you drive like a complete maniac, or there is something wrong with your car. Even driving pretty hard in a lot of city traffic before, I still always got in the 24-26 mpg range. If you're below 20 mpg on a 4th Gen your knock sensor or some other sensor is probably blown and might not necessarily throw an SES light depending on what it is. 4th Gens blow knock sensors all the time and that doesn't throw an SES light. Mine is blown, but it's bypassed. My mileage would suck right now in city driving without the bypass resistor. Probably teens at best.
Re: Are u happy with your gas mileage?
I am supercharged and very happy with the gas mileage, specially when I travel
almost 400Miles to a full tank of gas, 300 plus in the city with traffic
mecca how many gallons do u typically fill up at 280 miles? thats what u gotta look at, on a recent trip to montreal i averaged about 80 - 85 mph and got 29 mpg, and city i usually get anywhere from 21-26 mpg
Originally posted by 2k2wannabe
I let it go when it was just frank because we all know he can be a royal pain in the ***, but this made two so it's time to reply.
dont get mad im just stating my opinion
i always measure by filling all the way to the top, full tank...only way....
and this is bullsh*t!!! i just got 265 miles when the orange light came on and went back off...WTF, i expected so much more...car ran better and i was doing a lot of hard driving but i expected a good 300 with the harsh driving...grrrrr mUST I CHANGE EVERY 02 sensor?!
my car was throwing code: bank 1 cat. i just got the o2 sensor changed today..i hope it works..ill keep it updated next time i fillup hopefuly if i remember..this better work
300ish per tank and a 15ish gal refill.
For those of you that are getting bad mileage dispite a decent tuned engine, check your tire pressures. If the fronts are in the high 20psi range or lower, you might benefit from going to 33psi-ish fronts and 28-30psi-ish rears.
jesus christ, i just filled my tank up, put 15.89 gallons cost me 33 dollars!!!!
fck thats alot, to fill my tank here in the southern states has cost up to $24.00 but Jesus they are bending you guys over and sticking it in to you. One more thing I use Premium at all times
