HOWD YOU UNPLUG THE POWER ANTENNA??
remove plug
it has a latch, which keeps it in. If you can get your fingers and thumb on either side, you should feel it. Squeeze it to release.
If you plan to remove the antenna, remove the motor from the body first; the wires are long enough so you can pull the motor back towards where your jack stows, and you can actually SEE the connection, at which point disconnection will be obvious.
Good luck,
John
Good luck,
John
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
