I need some advise.
I need some advise.
OK I am putting the SC in my car. But this time I am going to go with a 2.875" pulley.
I also have the CAI, S-AFC, guages (EGT, Boost & FP), Cattman 2.5" exhaust and the light weight (non-underdrive) pulley.
I am also thinking of doing the Aquamist (or something like it) setup, J&S, and maybe a front mount intercooler.
Is this over kill?
Which of these last 3 things do I need? If any?
Would It be ok with just the water injection and the J&S?
Will the FMIC be worth the money?
Please give me your opions or ideas.
Is this over kill?
The minimum would be an Aquamist alcohol/WI system that turns on at say 6+psi for ~$420 shipped.
Besides the hp/tq benefits from an inter/after-cooler, an charge cooler would produce less wear on your engine and you'd get less detonation during hard runs or hot weather.
If the choice is EITHER WI or a charge cooler, I'd say get the cooler.
You don't need the J&S, until you start pushing 12+psi, so that would be my LAST purchase.
Originally Posted by Craig Mack
Good question. I'd say your at 12-13psi.
Considering cost and what HP gains I will get from all that.
And what kind of HP should I see.
Originally Posted by LatinMax
Am I not around or above 12 psi with a 2.875 pulley on a V2 and CAI?
I doubt you'll need J&S with a cooler, since he didn't with just WI(alcohol/water) and crap 91-octance Cali pi$$ water.
An properly sized intercooler *SHOULD* buy you a few more psi.
Someone posted a "do it yourself" WI kit a while back. It costs no more than $240 IIRC versus $420. Someone please post the site if they remember. What injectors are you running?? I thought that pulley maxes ours out. Ever think about a 30-50 shot instead. I'm still thinking of it for my 3.125 V2. If not then I'll follow your lead.
IMO to answer your post, the fmic would be fine especially w/ an NX N-tercooler (~$450). Or try intercoolertechniques.com for the same thing (~$200) check out the hp gains. good luck
I have been working on one that will run me around $100. It just has been easier to say Aquamist for question purposes. I wil do a write-up on it if it works.
Just don't hydrolock your engine by having a faulty "trigger/activator"....
Don't bother with ghetto kits unless you're using it just for an N-tercooler type deal.
$420 for the Aquamist is peanuts for what you get. EXTREME high quality and almost bullet-proof. Unless you're Kev of course and run it dry for long periods of time.
I was going to run a RV pump that has a shut off if you run it dry and a warning light to let you know that it was empty. And from what I looked at it runs at the same rate or a little higher than the Aquamist.
It is just a though.
The reservior is hooked up to the windshield washer light, so when it's low, I know.
Don't know if a standard RV water pump will work... Remember it's gotta overcome the boost PSI by a wide margin to get a good spray pattern...
Plus, don't you have a CEL and all kinds of rice blue lights staring you in the face too?
Suuuuure....then how did you manage to burn it up?;-)
Plus, don't you have a CEL and all kinds of rice blue lights staring you in the face too?:-)
The CEL is for the auto tranny, but the winshield washer light is different.
No rice blue lights.
So kev. Would you go with a FMIC or do you think that is overkill?
I'm not Kev, but EVERYTHING I've read says to stuff in the largest IC possible. However, that's usually stated in regards to a TC car, which isn't boost limited by a pulley, so you can always crank up the boost to make up for the drop.
I'll see if I can dig up some equations or net calculators to give you a ballpark idea of what size is right. However, whoever you choose to buy the IC from should be MORE then capable of telling you what intercooler is best for the room you have to work with.
Is this over kill?
Is this over kill?
I don't know how big the FMIC should be, but I agree with Alex that the seller should be able to recommend the best size.
Okay...no calculations, but some "tips".
Call SPEARCO (805)581-0333 and ask for their intercooler catalog. Once you decide on what type, ie bar/plate, tube/fin, or newer extruded tube/fin, they have "proprietary modeling software" for customizing to your needs. Probably BIG $$$$ though.
Bar/plate is a more efficient heat exchanger then tube/fin, but more expensive and can cause increased lag due to a greater pressure drop. The amount of pressure drop depends on density and design of fins. One type called "plain fins" allows lowest pressure drop, but not as great of heat transfer(not good!) compared to "louvered" fins or "offset" fins. Louvered or offset fins decrease air velocity, ie add pressure drop, however allow more time to transfer heat. Bar/plate also have a greater mass to soak up heat at low speeds like stop-and-go traffic and then release it once air velocity increases.
A larger surface area allows more cooling from the ambient air compared to a thicker core. 80% of the cooling occurs within the FRONT 2" of intercooler core, so bigger surface area with a MAXimum of a 3" core is recommended withOUT blocking too much radiator airflow. For increasing the surface area, it is better to maximize the height then widen the core, ie go taller rather then wider. The pressure drop is more when the charge air has to travel through a longer passage vs. a shorter passage, however the amount of drop can be minimized using a proper fin design to compensate.
Too large of an intercooler and turbo piping size contribute to lag. The recommendations for piping size are:
<300hp use 2-2.25 inch
<400hp use 2.25 inch from compressor discharge to the intercooler with 2.5 inch from intercooler to throttle body.
500+hp use 2.5 inch
500+hp use 2.5 inch
Thanks for the info. Is there anyone with a SC that is using a FMIC? and what are they using?
I am really liking the whole more power thing and what to be prepared if I decide to put the belt directly on the shaft
I know of one 5th gen that just switched to a turbo that had one, NOT sure what kind though. I do know he was selling it not to long ago.
Dohcser
24
Nov 15, 2002 03:17 PM
mightima
Nov 3, 2002 10:59 AM
FAST4DSC
Oct 12, 2002 06:34 PM
HondaKilLR
Oct 4, 2002 07:48 AM
JAIMECBR900
Sep 26, 2002 10:15 AM
