2001 Maxima O2 Sensors, how many?
Old Sep 22, 2003 | 05:23 AM
maxi-freak's Avatar
How many O2 sensors are on a 2001 SE?
Old Sep 22, 2003 | 05:28 AM
PIONEER's Avatar
FED Spec or Cali SPEC? 3 FED 4 Cali ?? I know the FED spec has 3 b/c I had a FED spec car.
Old Sep 22, 2003 | 05:57 AM
maxi-freak's Avatar
FED spec.
I guess that would be 1 upstream and 2 downstream?
Old Sep 22, 2003 | 06:03 AM
UMD_MaxSE's Avatar
Got Bent?
all 2001 maximas are cali spec... which means 4 O2 sensors...
Old Sep 22, 2003 | 06:22 AM
PIONEER's Avatar
I didn't know that, Maaf karna bhai
Old Sep 22, 2003 | 06:42 AM
maxi-freak's Avatar
I didn't either! But now things are starting to make sense. So that would mean that there are 2 upstream and 2 downstream O2 sensors?
Old Sep 22, 2003 | 06:47 AM
UMD_MaxSE's Avatar
Got Bent?
is all gooood
Old Sep 22, 2003 | 06:48 AM
UMD_MaxSE's Avatar
Got Bent?
yeah... 2 upstream that monitor A/F ratio... 2 downstream that sit behind the precats and monitor them....
Old Sep 22, 2003 | 06:56 AM
spirilis's Avatar
so for Cali-spec (my 2K has 4 O2 sensors according to OBD-II) they only have O2 sensors monitoring the precats, none monitoring the main cat?
Old Sep 22, 2003 | 06:58 AM
UMD_MaxSE's Avatar
Got Bent?
yes........
Old Sep 22, 2003 | 07:04 AM
maxi-freak's Avatar
Thanks UMD~ for the info! I've tested my O2 sensors and there is only one out of the 4 that cycles from .1 to .9. If there are 2 upstream, then shouldn't both of them cycle?
Old Sep 22, 2003 | 07:12 AM
UMD_MaxSE's Avatar
Got Bent?
the front two O2 sensors should have a relatively short cycle time... meaning they will pulse between ~0V to ~1V quickly. The downstream sensors will have a much longer cycle time. Make sure the system is in closed loop mode so that the sensors have heated up sufficiently.
Old Sep 22, 2003 | 07:32 AM
maxi-freak's Avatar
OK...I guess the upstream sensor on bank 1 is bad hence the PO420, because only the front bank 2 upstream sensor cycles.
Also the rear bank downstream sensor makes no change (slow) when I induce a lean or rich condition.
Old Sep 22, 2003 | 08:48 AM
Maxima Dan's Avatar
yes........
Wait a second, I just replaced two on my car and there is one sticking in the front of the main cat, doesn't that monitor the cat. Or do you need one in front and one in back of the cat to monitor it?
Old Sep 22, 2003 | 09:21 AM
maxi-freak's Avatar
The way I understand it is - we have 4 o2 sensors and 3 cats. There are 2 pre-cats and 1 main cat. There is one upstream sensor for each precat and 1 downstream for each precat.
The upstream sensor's output voltage cycles and the downstream sensors output voltages are based on lean/richness. The PCM compares the downstream sensor's output voltage with the upstream's (for it's bank) and makes the appropriate adjustment for fuel mixture - which is done by varying the pulse width for the injectors.
Old Sep 22, 2003 | 09:43 AM
OSoFast's Avatar
on a 3.0 max w/ fed. spec. we have 2 up stream at either side of the exh. manifold and 1 down stream just right before the cat.
Old Sep 22, 2003 | 10:21 AM
spirilis's Avatar
I always thought the PCM used the upstream sensor's output to determine leanness/richness, and made fuel trim adjustments based on the upstream sensors alone... the downstream sensors are ONLY used to analyze the efficiency of the precat catalyst. I know the downstream sensors don't change NEARLY as often as the upstream ones (if they do, the PCM knows the catalyst has failed and throws a catalyst efficiency code)
Old Sep 22, 2003 | 10:24 AM
spirilis's Avatar
Yeah, Cali-spec (mine's a 2K originally commissioned in NY state, shows OBD-II Calif on my OBD-II scan tool) has 4, 1 upstream on each bank, 1 downstream on each bank, whereas it sounds like FED-spec just has 1 downstream in the Y-pipe before the cat?
Strange how neither have an O2 sensor behind the main cat, which would be the most complete solution...
Old Sep 22, 2003 | 10:44 AM
UMD_MaxSE's Avatar
Got Bent?
the downstream sensors are used to regulate A/F ratio only if one of the upstream sensors is bad... otherwise, they do nothing.
Old Sep 22, 2003 | 01:43 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
On my 01 Max GXE 5spd I have 4 O2 sensors, One in the manifold on the front- one in the precat- front one, then one in the cattman Ypipe- the middle precat has been eliminated and I get no check engine lite. And the final upstream O2 is accutally in the part of the Ypipe that attaches to the rear exhaust manifold. The main cat- which I also don't have anymore has no O2 sensors in it like the older Maximas used to have. The post cat O2 sensors monitor efficiency of the cattalyst and if the cat has been damaged or removed it will set a check engine light. I am not sure why my car has not set a check engine lite for cattalitic converter below threshold after I installed the Cali spec Y pipe on my car, but as soon as I get my Cattman headers and remove the front precat I should find out if I will get a check engine light- I'm a Nissan tech btw so even if I get a CEL I can install a signal generator in place of the O2 sensor that is going to trip the code for the Cat that is no longer there
Old Sep 22, 2003 | 01:48 PM
UMD_MaxSE's Avatar
Got Bent?
hehehe... a simple 555 timer circuit and some caps and resistors should be enough to make a pulse generator that simulates the O2 sensors...
Old Sep 22, 2003 | 01:50 PM
Cutler's Avatar
Fed Spec owns Cali spec....
Old Sep 22, 2003 | 01:51 PM
UMD_MaxSE's Avatar
Got Bent?
quiet exploder boy
Old Sep 22, 2003 | 02:21 PM
maxi-freak's Avatar
I've actually thought of that as well. The PCM wants .1 to .9 with a 3hz frequency on the upstreams and .4Vdc on the downstreams.
Two double pole double throw switches could be used; one for bank 1 and one for bank 2. The output of each switch goes to the normal PCM IN and the inputs to the switches would be o2 sensor output OR home made circuit output. One pole input would be upstream o2 and the other would be the 555 at .1 to .9 @ 3hz. The other pole would be downstream o2 and the other would be .4vDC. So if you had a problem with bank 1...bam!.....switch the switch ...clear the code....and forget about it.
Old Sep 22, 2003 | 02:55 PM
yeah but my whole thing about this is... its only if I get a CEL for removing of the precat with the new Cattman headers. If thats the case- I will need to hook up a few radioshack pieces up and make up my own "cat" in a chipset :P I'm not removing the O2 sensors.
Old Sep 22, 2003 | 06:22 PM
maxi-freak's Avatar
So BlackBird...does it sound like I have a bad cat or o2 sensor? Should BOTH my upstreams be cycling?...cause only one is. I've got the PO420.
Old Sep 22, 2003 | 06:44 PM
Maxima Dan's Avatar
Maybe this is a stupid question, but have you had the ecu reflashed?
Old Sep 22, 2003 | 08:06 PM
the UPSTREAM O2s have to cycle on and on from like .9 to .1 v or so inbetween... if they stay on one spot for too long U got a lazy O2 sensor and its causing U to get ****ty gas mileage. But then again U will get a O2 sensor dettoriration code.
Old Sep 22, 2003 | 09:33 PM
Cutler's Avatar
quiet exploder boy
shut it tan maxima
Old Sep 23, 2003 | 06:35 AM
maxi-freak's Avatar
I have had it flashed and the code came back within a week.
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
District
Aug 15, 2015 08:23 PM
wpr
Aug 5, 2015 03:28 AM
yat70458
Aug 3, 2015 01:16 PM
