Stllen Drilled Rotors - Anyone Used Them
I'm considering Stillen drilled rotors as a replacement to the stock on 2001 SE AE.
Anyone ever use these?
Opinions?
Other brands liked better?
Opinions?
Opinions?
Opinions?
I have them and they are a bit better than stock. They look better then they perform.
Just fine here
Originally Posted by Padsy
Mine have worked fine....12K miles and counting.
25k miles on my stillen (which actually, are brembo rotors... it's etched into the rotor) cross-drilled, and no problems.
Don't know if they perform any better than stock, I had new pads and stainless steel lines put in at the same time...
Looks cool
Slight hairline cracks are "normal" around the drilled areas - you'll see that over time if you push your brakes to their limits.
I've had mine for quite some time now (they've outlived the factory ones a twofold so far). Also, they're a little thicker than stock which helps..
Thanks for replies
Thanks for the replies, I don't race the car or push the brakes to the limits. I just have never felt that this car stopped very quickly and was hoping to improve stopping power without spending $2500.00 on a major upgrade.
I'll take your comments under advisement.
FYI, I did the driving light rewire - very happy with the results.
Apr 16, 2020 05:15 AM
