Superchargers
Old Sep 25, 2003 | 02:59 PM
03SEMAXIMA's Avatar
Superchargers
Does it matter how many miles a car has to put on a supercharger. i am asking cause people have told me if i put a supercharger on a car that has alot of miles it will blow the motor and i was wondering is this true
Old Sep 25, 2003 | 03:47 PM
Street Reeper's Avatar
Handsome
Check the compression. VQ's are very well ballanced and should not give you any problems as long as you give it enough fuel, and monitor your gauges. I am about to SC my 4th gen at about 85,000, I was originally going to wait until around 100,000 miles. Basically the only thing that I am going to do is first get a compression test, switch to mobil one synthetic, get a walbro fuel pump, FPR, SAFC so that I am sure that my engine is getting all the fuel it needs, and finally gauges so I can monitor everything.
I can't remember who it was that tore down their VQ after 85,000 miles of boosting and spray but it still had the cross hatch marks! These engines are great, treat them right and they will last you forever.
Old Sep 25, 2003 | 05:28 PM
Craig Mack's Avatar
All YOUR grammer belong to me
I have ~83,000 miles on my '95 SE, about 12,000 miles with the supercharger, with no problems. I have around 60,000 miles on the supercharger (bought it used), about half with a smaller pulley, and it too has been good to me. I am not running synthetic, NOR do I plan to. I run the cheap stuff, but have starting using Castrol Syntec Blend. Supercharging demands that you change your oil at least every 5,000 miles. So far, with 12,000 miles at almost 10psi, my engine has been perfect. God bless those little fellas at Nissan who brought about the VQ engine back in mid '94.
Old Oct 7, 2003 | 12:09 PM
maxlinegtr's Avatar
How about at 145,000 miles....where can I get a compression test?
Old Oct 7, 2003 | 12:19 PM
[maxi-overdose]'s Avatar
you can buy the compression gauge and do it yourself. or have a mechanic does it for you.
refer to Hayne's repair manual for more info and how-to.
Old Oct 7, 2003 | 01:13 PM
maxlinegtr's Avatar
THANX
Old Oct 7, 2003 | 02:19 PM
JAY25's Avatar
well lets see, I seen two motors one at 135K boosting 8PSI, then I see another who just got supercharged @ over 100K, and a third max who went thru nitrous and now pushing 10PSI from a Turbo and they are both running strong and I just bought a 95 max with 135K and thats running strong about to add some bolt ons
Old Oct 7, 2003 | 09:26 PM
96shogunmax's Avatar
mine was boosted at 150k
9-10psi
Old Oct 8, 2003 | 03:48 PM
ereet's Avatar
100k miles on an SE, 10psi of boost, running one of the smallest pullies available (3.00")
Been on for 12k miles, 0 problems. For the most part, the VQ is a helluva strong engine.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Cumalot
Nov 28, 2000 09:38 AM
Mabfnar
Oct 24, 2000 11:17 PM
