cons of tsb's
Old Oct 7, 2003 | 02:30 PM
Maxnut's Avatar
cons of tsb's
I am taking my car in tomorrow and plan on asking the dealer to do several tsb's including, lack of power, xenon headlamp theft deterrent kit, hood shudder, and wind noise. Has anyone had any bad experiences after having a tsb done? I am mostly concerned about the hood shudder, wind, and xenon tsb's. I do not want to drive out of the dealership worse off than when I drove in.
Old Oct 7, 2003 | 02:36 PM
92 SE-R 02 SE
i took my 02 for almost all the things you asked for. they fixed the wind noise, hood rattle (man it was BAD!!!) the HID kit i wont pay for, and my 02 doesnt have the lack of power. dealers know about most of the problems, so all should work out...
Old Oct 7, 2003 | 02:53 PM
IgS's Avatar
IgS
im thinking to take it in for wind noise....how long did it take? im asking because my shedule is pretty busy.
thx
-IgS
Old Oct 7, 2003 | 03:59 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Besides the "Can't duplicate" or "That's NORMAL" lines, they can AND will break sheit, scratch sheit, and *** up 2-3 other things for every one they fix. At least that's my experience.
Anyways, I'd have them perform the lack of power TSB, forget about the "theft deterrent" kit, and perform the hood and wind noise TSBs yourself.
Good luck!
Old Oct 7, 2003 | 05:04 PM
Maxxxed's Avatar
tEh Hope
I own an 03 Max SE. Occasionally my car seemed sluggish, I asked them to do the "lack of power" TSB. He looked up his computer and told me that my car will qualify for reprogramming but I will still have the same old MAF... Before doing it, he told me that our cars are sluggish and its normal. He also told me that if they reprogram my car will burn more fuel etc. I asked him to go ahead with the update.
I think both our engines do not qualify for MAF replacement... so I am not sure "lack of power" TSB will do much. I did find the car to be running a bit smoother and more responsive, but I think I need a week to judge the difference...
Old Oct 7, 2003 | 05:26 PM
bluemaxx's Avatar
Moderator GT-R
I took my 2k1 AE in for the fuel cut off tsb and it was never the same after that.
When I bought the car it had personality, ran like a spotted assed ape. After the TSB it was ho/hum performance. As far as I know the SE and AE had the same engine, AE advertised 5 extra HP from the muffler. I'm skeptical about the muffler though. I think they tweaked the ECM of the AE and the TSB programmed it like any othe SE.
After the TSB it was disappointing. I even had them bump the timing to 17btdc, no help.
ECM TSBs scare me.
Old Oct 7, 2003 | 07:34 PM
trey
Hey maxxxed, I'm trying to figure out if my car needs the "lack of power tsb". Was your car sluggish when acelerating from a stop or what?
Its like i want to get something if its entitled to me but i'm not sure if i need it ahah.
Old Oct 7, 2003 | 08:10 PM
Maxxxed's Avatar
tEh Hope
trey, yeah it was sluggish when accelerating from stop. Sometimes engine would run a bit rough like its pulling extra weight or something... I just had this TSB done today, overall I feel some difference, maybe its just in my head. If your dealer agrees to do it, just get it done... you'll "feel" a little better knowing that you used a little bit of your warranty
Old Oct 7, 2003 | 08:20 PM
IceY2K1's Avatar
The AE has a different ECU part number.
ECM TSBs scare me.
Old Oct 7, 2003 | 08:22 PM
trey
Thanks man, i'm gonna wait a while since my car seems perfectly normal, i haaaaaate bringing my car in anways
Old Oct 7, 2003 | 09:20 PM
bluemaxx's Avatar
Moderator GT-R
But was there a different TSB for AE fuel cut off vs. SE fuel cut off? I don't think so. I think they reflashed my ECM with the regular code thus wiping out any advantage that Nissan may have tuned into the AE ECM.
I still don't buy the 5 extra HP due to gizmo valve in the muffler krapp.
Old Oct 7, 2003 | 11:28 PM
IceY2K1's Avatar
Me neither, but DAVEB says they are indeed different. What the difference is he doesn't know.
Do you have a OBD scanner by chance? Mine tells me the part number and I'd like to know what yours has. DAVEB can also tell you from your VIN# if you're curious.
Old Oct 8, 2003 | 09:31 AM
TimW's Avatar
The silent but deadly Moderator
cons of tsb's?
You mean the cons that perform them?
Old Oct 8, 2003 | 10:50 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i would like to know the difference and i do have obd2 software.
Old Oct 8, 2003 | 11:10 AM
IceY2K1's Avatar
Call DAVEB at (888)254-6060 to give him your VIN#. Hopefully, he isn't busy.
Anyways, on my Alex Pepper OBD software, I can do a VIN, CVIN, etc... check, but only one works and it happens to return the ECU part number. Can you do the same?
Old Oct 8, 2003 | 11:34 AM
Craig2kGLE's Avatar
The con of having TSBs done is that most dealers either a) don't care, b) don't know what they're doing, or c) all of the above.
I had the wind noise TSB done. I'm still trying to get the silicone gunk off my leather seats, and I still have to scrub it from my windows whenever I decide to lower them and put them back up.
I had the brake judder TSB done, and the problem returned a couple of weeks later. They didn't replace the pads, even though the TSB calls for it, because "that's just a guideline, and we choose what to follow."
I had the 1-2 slow shift (auto tranny) TSB done, and the car has shifted even slower since the "fix". As a consolation prize, the dealer scratched the interior driver's door panel with a screwdriver.
Come to think of it, even an oil change comes with benefits. Last time I had scratches on the car that weren't there before. I consider a successful Nissan service experience one that does not cause additional damage to the car.
YMMV.
Old Oct 8, 2003 | 11:42 AM
Darth Vader's Avatar
Just had the hesitation TSB done today. Very happy with service and results.
Old Oct 9, 2003 | 11:06 PM
mattattax's Avatar
Can you get a TSB done if you're past warranty?
Old Oct 10, 2003 | 10:14 AM
MaximaDisciple's Avatar
You'll probably have to pay for it.
Old Oct 10, 2003 | 10:46 AM
Maxxxed's Avatar
tEh Hope
If you are past warranty period, you are on your own - just slightly different from when you had warranty.
Old Oct 14, 2003 | 04:25 PM
Maxxxed's Avatar
tEh Hope
... I did find the car to be running a bit smoother and more responsive, but I think I need a week to judge the difference...
OK, I had "lack of power" TSB done about a week ago. They updated the software and I am not sure if they replaced my MAF. He highlighted the part number 237106Y314 and commented as "updated #". I am not sure if this is a new MAF or my old one...
The first three days (after I had the TSB done) my ride was just amazing. My car was very quick and responsive. Automatic gear shifting was smooth, everything was just great... Slowly it lost its edge and now its back to being sluggish. I have no idea if this is mechanical issue or the software or the MAF itself. Does anyone have any idea why this is happening? Do I have to buy different MAF and install it myself to achieve better results?
Old Oct 14, 2003 | 04:47 PM
IceY2K1's Avatar
Using past Nissan TSB ECM part numbers listed on a TSB I have, it says the 6Y31X is a "Vehicle with an updated airflow meter", so I think you've got a new one.
I would perform the ECU reset procedure and Drive-by-wire reset procedure shown in the How-To sticky or search for the thread. If that gives you back the "amazing", "quick and responsive" feel I'd find out what the dealer has to say about that.
Old Oct 14, 2003 | 05:59 PM
Maxxxed's Avatar
tEh Hope
IceY2K1, thanks man for your help... I will reset the ECU tomorrow. How do I do Drive-by-wire reset? I did not find anything about that.
Also, I forgot to add that when accelerating the gas pedal resists against push and I have to apply more pressure to accelerate. I am not sure if this is a related problem...
Old Oct 15, 2003 | 11:21 AM
Maxxxed's Avatar
tEh Hope
Can someone tell me how to do Drive-by-wire reset... thx.
spencerwh1
Jun 30, 2016 05:44 AM
doctorpullit
Oct 11, 2015 10:28 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
