can anyone recomend a good fuel injector cleaner aditive?
Old Oct 7, 2003 | 07:31 PM
infinitiman96's Avatar
My 98 I30 has a rough idle, and after replacing all 6 coil packs i've come to the conclusion my idle problem is injector related. I've already replaced the fuel filer, plugs, and cleaned the throttle body to no avail. Anyway i'm wondering if anyone could recomend a good fuel additive that may unclog my injectors, i've tried the stp stuff every oil change but it doesnt help. Is techron worth the money?
Old Oct 7, 2003 | 07:34 PM
outsider's Avatar
the cheveron techron fi cleaner is only like 5 dollars so just throw a bottle in there and see what happen
Old Oct 8, 2003 | 07:40 AM
theres 2 different kinds of techron though
Old Oct 8, 2003 | 08:27 AM
Dreizehn's Avatar
I use BG products 44K
http://www.bgprod.com/bgprofessional.../autofuel.html
Old Oct 8, 2003 | 09:38 AM
ZuMBLe's Avatar
I'll vouch for this stuff too! Which reminds me.. Time to get another can.
Originally Posted by MadMax95
Old Oct 8, 2003 | 09:49 AM
LiquidNine's Avatar
yeah, BG 44k is the best available. Expensive, but well worth it.
Old Oct 8, 2003 | 10:33 AM
DoGGy
how much is BG 44k?
Old Oct 8, 2003 | 10:50 AM
maxNYC's Avatar
How do you know its well worth it? are the gains or reving evident? I'd spend the extra money if it were justified. The chevron stuff is just as good.
Old Oct 8, 2003 | 12:42 PM
ohannon7's Avatar
So if you do get the techron stuff........do you fill up w/ the highest rated gas, add the techron, then drive it really hard till empty???????
Old Oct 8, 2003 | 12:50 PM
Dreizehn's Avatar
It corrected my rough idle. I've never used the chevron stuff. I have a friend that works for BG so....
Old Oct 8, 2003 | 01:05 PM
95seMax's Avatar
I Also want to know how u drive wen its in the tank , are u supposed to drive hard to burn it up faster?
Old Oct 8, 2003 | 02:42 PM
Dreizehn's Avatar
I don't see any need to. Just drive normally. If you drive like a bat out of hell, continue driving like a bat out of hell...
The cleaner going through the injectors is what cleans it. I can't imagine if it goes through faster it would do any better than if the same amount went through at a slower pace.
Just my $0.02
Old Oct 8, 2003 | 02:44 PM
ivelweyz
That AUTO RX stuff is apparently the best ****, whatever it's called. $25 a bottle but everyone on the org who used it recommends it...
Old Oct 8, 2003 | 03:08 PM
jt151's Avatar
A lot of FI problems these days
Just go to a local lube place and have them do a Fuel system cleaning. It really works!!!
Old Oct 8, 2003 | 04:13 PM
Kevlo911's Avatar
Kevlo for President
i used marvel's mystery oil and it worked just fine, it was like $2.50 per bottle
Old Oct 8, 2003 | 04:39 PM
2naboy's Avatar
I use techron and I run the car until the gas is all the way down then I put in the cleaner, drive a long way to a gas station. As I'm driving, I really feel the difference.
Old Oct 8, 2003 | 04:44 PM
MattyO's Avatar
I agree BG 44k I ran that last week. Good Stuff
Old Oct 8, 2003 | 05:36 PM
nismos14's Avatar
§è~® f®ÈÄk
i didnt feel any difference with chevron techron didnt affect anything, i guess my injectors were pretty clean already
Old Oct 8, 2003 | 07:08 PM
how much is the BG 44k?
Old Oct 8, 2003 | 07:43 PM
Jatan's Avatar
Around $20 a can
Old Oct 9, 2003 | 04:39 AM
LiquidNine's Avatar
the 44k product is what many dealerships use... it's much more concenrated than other off the shelf cleaners. Since you are spending the money on the fuel system cleaner, I'd reccomend to first do a Throttle body cleaning, then upper intake cleaning while you are running your tank w/ bg44k in it. This way, your throttlebody gets cleaned and extra gunk goes into your plenum... your plenum gets cleaned and extra gunk goes through your combustion chambers (if you do the 'car running' method).. and the bg44k cleans up your fuel system and combustion chambers. This is exactly how my local nissan shop cleans the air intake, fuel and combustion components.
Clean combustion chambers are important as carbon in there can lead to hot spots.. which leads to knock... 0304 codes (for those who beleive that knock detection can throw the 0304) and poor performance.
Do not feel the need to drive the car hard while you have the 44k in the tank. Simply pour in the 44k (use a funnel, you'll be glad you did) and then fill your tank w/ premium gas, which you should be using anyways. Drive like a soccer mom until the tank is near empty and enjoy your clean system.
Old Oct 9, 2003 | 11:13 AM
ardika's Avatar
LiquidNine,
I am currently having knocking problems at around 2k. Currently I am putting the Auto Rx and BG 44k in my tank and one of our member suggested spraying the Throttle Body/Intake cleaner with engine running.
The whole thread is here:http://forums.maxima.org/showthread.php?t=254345
Seems to me that I need to do this for my last resort.
Old Oct 9, 2003 | 11:34 AM
NewbieNissan's Avatar
the 44k product is what many dealerships use... it's much more concenrated than other off the shelf cleaners. Since you are spending the money on the fuel system cleaner, I'd reccomend to first do a Throttle body cleaning, then upper intake cleaning while you are running your tank w/ bg44k in it. This way, your throttlebody gets cleaned and extra gunk goes into your plenum... your plenum gets cleaned and extra gunk goes through your combustion chambers (if you do the 'car running' method).. and the bg44k cleans up your fuel system and combustion chambers. This is exactly how my local nissan shop cleans the air intake, fuel and combustion components.......
Question how does one go about cleaning the TB without removing the Air Filter box + oil sep as disccussed on motovate...
I would love to spray clean my TB and not have to destroy my hand anymore (seriously why does the max have so much sharp edges was the intention not to have mech work on or just DIY'er)
I live in mia does anyone know of a location to pick up BG 44k (someplace like a napa parts)...
TIA
Always smiling at the SUN (1)
Old Oct 9, 2003 | 11:47 AM
Dreizehn's Avatar
10 characters...
Old Oct 9, 2003 | 02:42 PM
Max Noob's Avatar
just use chevron techron feul system cleaner, not jsut the injectorcleaner. i have heard that there is some factory coating on the partsthat keep deposit off the fuel system. if you use too much of the fuel cleaners u strip the parts of the coating. if you never used the cleaners before jsut use a whole bottle with a full tank of gas. you'll notice a difference. i dont know about using it every 6k though.i find myself buying a bottle every year.
Old Oct 9, 2003 | 06:04 PM
DoGGy
how often should i use a bottle of BG 44k? my max has 25k miles and im not sure if its necessary to use a can
Old Oct 10, 2003 | 05:33 AM
LiquidNine's Avatar
I reccomend cleaning the TB w/ the spray and rag method w/ the car off... then spray in an intake cleaner (I used AMSOIL Power Foam - not reccomended to me by anyone on the .org, I just went for it) while the car is running. Remember to disconnect the electrical connections to your maf before you start your car w/ the exposed TB. you'll throw a CEL for a maf failure or circuit break, but it's no big deal to reset.
I don't like the method of spraying in intake cleaner with the air intake system still attached... especially if you are still using the stock resonator where a midpipe would be because it's a resonator and oil separator - thus, not a straight shot to your TB. The inside of that resonator is contoured with valleys that lead to the interior of the resonator. From what I've seen, when you spray the cleaner into the intake, it tends to slide along the walls of the intake and I want all the cleaner to go straight into the TB and upper plenum. It's easier to do this when everything is detached and you can spray it yourself direct to where you want it to go. I think sliding the 'straw' of the spray can in to a gap between the couplers far to much of a PITA... it's easier for me to just remove the intake resonator and MAF. The one time I did the straw through the coupler method, I was unhappy and completed the cleaning by removal of the resonator and MAF.
Old Oct 10, 2003 | 11:34 AM
JustTry's Avatar
Try replacing your PCV valve...its only a few dollars, and that may help your idle.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
pkfinn
Jan 3, 2016 02:55 PM
pkfinn
Sep 13, 2015 08:01 AM
Tha'-Max
Aug 30, 2015 01:14 AM
Balkins
Aug 12, 2015 06:39 AM
