Taping Oil Pan.. do i have to remove it.
Old Oct 15, 2003 | 03:02 PM
bobjohnson's Avatar
Blazin......
Hey i wanna hook this oil temp sensor to my oil pan. its like the size of the supercharger tap-in. I just dont want to Re-move the entire oil pan for this ordeal.
how longs it take to take it off? difficult?
Or should i just do this and leave it on-> http://www.superchargersonline.com/content.asp?ID=30
Old Oct 15, 2003 | 07:47 PM
bobjohnson's Avatar
Blazin......
yo taco,,,,,,
Old Oct 15, 2003 | 08:03 PM
VQvroom's Avatar
I wish i could help you out bro but ive never done it. I do know one thing from experience. The job is always easier when u take the longer road it seems. I would imagine the job would be much easier in the long run by actualy dropping the pan. Plus you can clean it all out when its apart.
Old Oct 15, 2003 | 08:06 PM
bobjohnson's Avatar
Blazin......
Yeah im thinkin that too. That pans gotta have some oil globbed inside it and probably could use the cleaning. Ahhhhhh ya talked me into it. To the dealer for a gasket it is.........
Old Oct 15, 2003 | 11:16 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
its actually alot of work to remove the upper oil pan, if thats the one your talkin bout. lower oil pan is easy. btw, there is no oil pan gasket, juss high temp silcone.
Old Oct 16, 2003 | 09:53 PM
Lonely Driver's Avatar
I teed my oil temp sensor at the oil pressure switch.
Old Oct 17, 2003 | 05:49 AM
nupe500's Avatar
Jedi Knight
bob,
why exactly are you putting in that temp sensor...just to do it? I thought you put in a tranny cooler, or do you just want to monitor that?
Old Oct 17, 2003 | 08:12 AM
Stephen Max's Avatar
You'll need to tap low enough so that the sensor is immersed in oil. You might as well just remove the lower oil pan and tap there.
I have an Autometer oil temp gauge and I put the sensor in the drain plug. I drilled through the center of the plug with a 3/8" drill, which was just a hair smaller than the sensor diameter. I heated up the plug with a torch and tapped the sensor in with a small hammer. There is enough interference to make a tight, leak-proof fit.
MatthewsMaxima
Sep 11, 2015 03:21 AM
sdotcarter
Sep 2, 2015 09:53 PM
lexcitement
Sep 2, 2015 09:48 AM
A32goldylocks
Sep 2, 2015 06:39 AM
raffivegas
Aug 23, 2015 09:54 PM
