melted connector/fire
Old Oct 16, 2003 | 05:19 AM
ornery1's Avatar
my 2k with euro dezigns 100/80 watt xenon bulbe melted the connector that plugs into the bulb! luckily i smelled it cooken pulled over and disconected it. did this happen 2 anybody else? replaced the plug 1.99 and it does not get hot,other side wich is factory gets hot, ill replace that one next
Old Oct 16, 2003 | 05:10 PM
ornery1's Avatar
anybody???????"??
Old Oct 16, 2003 | 08:40 PM
ornery1's Avatar
i cant b the only 1????
Old Oct 16, 2003 | 08:43 PM
looslip's Avatar
Horra!!
You should've antied up and got some PIAA's dude.
Old Oct 17, 2003 | 03:28 AM
MIXXMAX's Avatar
Whenever you increase the wattage that much as compared to what the stock harness can handle, don't even risk trying to use the factory harness. Eventually it will burn and ruin the harness! Why don't you just install a higher wattage harness and be safe?
Old Oct 17, 2003 | 10:59 AM
maseo77's Avatar
yes this happened to me when i 1st bought the car and was too cheap or didnt know about hids, went thru about 4 sets of "hid look" bulbs b4 my harness started smoking one day then i went and got some 7000k's
Old Oct 17, 2003 | 11:51 AM
Kojiro_FtT's Avatar
Yup, standard issue with "Xenon" halogens. My freind melted his and has to replace the whole harness in his WRX. He is so bitter. Now he's like "I don't care about HID or looking HID, it's gay!" Well, it wasn't gay until you melted your harness, lol.
Anyways, point is it happens.
Old Oct 17, 2003 | 11:58 AM
ornery1's Avatar
what is 7000ks
Old Oct 17, 2003 | 06:46 PM
maseo77's Avatar
what is 7000ks
its the color and brightness of my hids
Old Oct 18, 2003 | 08:35 AM
NissanMasterTec's Avatar
I see it all the time, you overloaded the circuit by putting in those higher wattage bulbs.
It is basic electrial theroy.
more wattage = higher current(Amperage)
higher amperage= excessive load on the circuit
excessive load on a circuit designed to run at 10 amps that is now pulling
say 15 to 18 = heat
heat melts things as you found out
Old Oct 21, 2003 | 04:37 AM
andrew3616's Avatar
Where did you buy the new plug??? This has just happened to me too!!!
Old Oct 21, 2003 | 07:13 AM
ornery1's Avatar
strauss auto 1.99
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
jerrod99_se-l
Aug 24, 2015 10:24 AM
matt92gxe
Jun 19, 2002 09:06 PM
Gary95
May 16, 2002 11:45 AM
[maxi-overdose]
May 8, 2001 10:37 PM
