Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Looking for feedback on my dyno
Old Oct 18, 2003 | 08:17 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
I dynoed last Saturday and I have mixed feelings on it. The dyno is here Peak hp is lower than expected for my mods but torque seems about right. I have be unable to locate any dynos for stock 00-01 auto so I do not have a baseline to compare it to. I was curious if some of the dyno experts could take a look and tell me if there signs that indicate any problems. Only thing else changed besides the mods listed on the page were copper replacements in stock heat range gapped correctly. Any advice or insight would be greatly appreciated.
Haydn Jr.
Old Oct 22, 2003 | 11:07 AM
NmexMAX's Avatar
dot dot dot ...
Seems about right if you're auto. But, your mods should have brought it up more. BTW, where did you get your timing advance at? And on your plot link, you said all runs were run in 3 gear, up to 65 mph? w O/D off? I didnt follow that. But it does seem alittle low. Maybe i's just the dyno.
Old Oct 22, 2003 | 01:01 PM
sloppymax's Avatar
i had the timing advanced with a consult 2 at a local nissan/infinite specific shop. for my runs, i ran it up in 3rd gear to 65mph with o/d off and just hit it from there. at 65, it wont downshift into 2nd and keeping the o/d off locks me out of 4th so i run 3rd all the way to redline since 00-01 make peak hp right around redline due to the variable intake.
Old Oct 22, 2003 | 07:33 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
a stock 00-01 automagic dynos at about 165 fwhp with a low of 160 and a high of 170. Yeah you should had a bit higher peak numbers.
Check general maintenanc issues, and also tire pressure/alignment, y-pipe flex section, etc.
Old Oct 28, 2003 | 08:04 AM
JMAXIMA's Avatar
how would the flex section affect dyno #'s that much? i know i have a loose flex section in my budget ypipe, could that be a reason of my low numbers?
Old Oct 28, 2003 | 10:54 AM
sloppymax's Avatar
if the flex begin to crumble inward and create a strangle on the air coming through. it affects boosted guys alot more than N/A but it can still bring down hp and torque.
Old Oct 28, 2003 | 11:04 AM
Blu's Avatar
Blu
the tits
yes if you mean the flex section is collapsing...
Old Oct 28, 2003 | 05:31 PM
JMAXIMA's Avatar
dunno if it is collapsing or not... haven't had enough time to look inside.... from the outside it looks ok.... but it rattles like a ****** phucker.
Old Oct 28, 2003 | 05:35 PM
sloppymax's Avatar
most do look fine from the outside. the best thing do is seperate from the cat and check out the inside with a flashlight. i was trying to wrap my flex section and i hit the flex section with the side of my hand a few times due to frustration. after i started the car, i had black smoke come out of the exhaust so obviously carbon was getting caught in there.
Old Oct 29, 2003 | 03:09 AM
JMAXIMA's Avatar
thanks... i'll check it out sometime this week...
Spartan1310
Sep 28, 2015 08:03 AM
MannyMonroe
Sep 25, 2015 12:38 PM
soybeanz
Sep 25, 2015 10:46 AM
ac max 92
Sep 17, 2015 07:35 AM
