Knock sensor code and wierd idling.
Old Oct 18, 2003 | 01:21 PM
MikeD95SE's Avatar
Ok so I have been having some wierd idling problems lately so I was using my multimeter to check my TPS.
The car will idle high and when I step on the gas pedal and release it the idling goes down.
I first checked the TPS and here was the reading I was getting from my multimeter:
without the gas pedal pressed it was coming up as around ~950 OHMS
which seems high.
At WOT it was coming up at ~4000 OHMS which I believe is correct at WOT.
I forgot to write down the exact numbers...
I check a little later and with the gas pedal pressed i was getting a ~460 OHMS reading.. Does anyone know what the reason can be that it was a higher reading when I first took it?
FYI: This test was taken with the car off and the car was warmed up.
I am also having some hesitation issues. I went to check for ECU codes and I am getting a knock sensor code. Can this have anything to do with idling or does this seem like a TPS problem?
Thanks,
Mike
Old Oct 18, 2003 | 06:54 PM
Jatan's Avatar
Check the reading on the KS, it should be like 550k. If the KS code is the only code from the ECU, then your KS is probably bad.
TPS: http://vbxmaxima.8m.com/tps.html
Make sure you are running premium fuel (are you using premium now???) and do the KS resistor mod. If it solves your problem, then your KS is definitely the only problem If not, then you have some other problem and the KS problem Good luck
Old Oct 18, 2003 | 07:26 PM
MikeD95SE's Avatar
I use super fuel. Im probably going to pick up a new knock sensor some time soon cause my car feels sluggish at low RPM's
Old Oct 19, 2003 | 12:22 AM
Nismotic's Avatar
Always sunny in philly
fyi i recently changed mine and the sluggishness in the lower rpms disappeared.
Old Oct 20, 2003 | 06:52 AM
MikeD95SE's Avatar
Was your ECU throwing a code for KS?
ballerchris510
Sep 23, 2015 08:46 PM
homeofbacon
Sep 23, 2015 07:17 PM
ac max 92
Sep 17, 2015 07:35 AM
