90 Maxima Won't go into gear when cold
Old Oct 18, 2003 | 06:47 PM
vipmsi's Avatar
I have a 90 Max that will start every time ~~ however when it gets cold sometimes the button on the shifter will not depress so that I can shift out of park ~~ only happens sometimes and only when below freezing. Dealer did not find anything.
Old Oct 19, 2003 | 12:38 AM
davebond007's Avatar
Well I was about to say to change your transmission oil (ie, put in some Redline), but you have an auto.
Sloppy shifting usually means your transmission is on the way out. Save some cash and swap in a 5spd. Be sure that you get an old 92-94 SE transmission that has the limited slip diff. Check E-bay for prices.
Old Oct 20, 2003 | 07:57 PM
vipmsi's Avatar
I do appreciate the reply ~~ however I don't have any shifting problems. The only thing that happens is that the button seems to freeze so that it cannot be depressed, so that I can shift. If I let it warm up a little and restart it several times I can then depress the button to be able to shift. Works well all summer and most of time in the winter. Only happens when I am running late to work ~ Hummmm ~~ maybe I am on to something.
Old Oct 20, 2003 | 08:51 PM
grody's Avatar
Do you get a clicking sound when you press the brake pedal? Can you shift out of park if you use the manual override at the base of the shift lever? Sounds to me like a bad connection somewhere in the shift lock loop.
Lakersallday24
Nov 7, 2024 07:31 PM
Quickgtp
Apr 13, 2017 03:30 PM
acw
Aug 13, 2015 12:50 AM
Hawkeye61
Aug 12, 2015 06:45 PM
kirkhilles
Aug 8, 2015 10:53 AM
