1995 M3 Comparison?
Old Oct 22, 2003 | 05:53 PM
FrankTheBunny's Avatar
1995 M3 Comparison?
Does anyone know what kind of numbers a '95 M3 puts down? I tried searching the web, but all I came up with is stuff for the European model.
Just curious how it stacks up to my '03 6spd. OBVIOUSLY it's going to handle like a dream... but how's the power compare?
Thanks...
Old Oct 22, 2003 | 05:58 PM
bigdo26's Avatar
They should do 0-60 in about 6 seconds flat (give or take) and the 1/4 in mid 14's @ 95-97 mph. Quick cars
Old Oct 22, 2003 | 06:11 PM
maximadave's Avatar
detailerdaveb@gmail.com
from BMW World:
The E36 M3 for North America was first produced as a 1995 model with the S50 US B30 engine. Horsepower output is 240 at 6,000 rpm, while the torque peak of 236 lbs/ft occurs at 3,800 rpm. The car can go from 0 to 60 in 5.9 seconds, with a quarter-mile in 14.3 seconds at 98 miles per hour.
Old Oct 22, 2003 | 06:41 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
More than a match for 4th/5th Gen Maximas...
Old Oct 22, 2003 | 08:26 PM
MONTE 01&97 SE's Avatar
Good match for 02/03 more than for 95-01's stock that is.
Old Oct 22, 2003 | 08:36 PM
bigdo26's Avatar
ya it'd be an excellent match for the 02/03's. on the straits at least
Old Oct 22, 2003 | 10:50 PM
ChromeSE5's Avatar
I can hang but slowly lose it to my friends 96 M3. I pretty sure a 2k2 or 2k3 can hold its own.
Old Oct 22, 2003 | 11:14 PM
Gooey's Avatar
i raned the older m3 when i had my 2k2 gxe and i beat if off the line up to 120 then it started catchin up to 130 and we stopped
Old Oct 22, 2003 | 11:19 PM
Jeff92se's Avatar
I'm needing a caw
Those M3s are high revers. If the driver is good enough to drive the car properly, any pre-2002 maxima is toast unless heavily modded
Old Oct 23, 2003 | 07:52 AM
HondaKilLR's Avatar
The 95's seem to have a bit less torque than it's predacessors (3.2's), but make sure he is not chipped or he will burn you....OBD I baby.....throw a european MAF on that thing and watch out!.......Just a heads up..........You should be able to see it thru the front grill/ brake cooling duct if he has one. Peace_
Old Oct 23, 2003 | 09:10 AM
F23A4's Avatar
I ran two different E36 M3 coupes (5 speed) on the same stretch of Route 1 - Edison NJ with similar results: Fully hung with them through their 1st & 2nd gear but got pulled on in their 3rd gear. Caveat: My 2K2 is an automatic; I can only speculate how good a well driven 6sp could do against it.
Peace.
Old Oct 23, 2003 | 11:01 AM
vsamoylov
my brothers 1997 m3 hit o-60 in 5.4 seconds and a quarter at mid 14s. very quick
Old Oct 23, 2003 | 12:02 PM
Virus's Avatar
1995 M3 0-60 6.2 1/4 14.6
Obtained from www.car-stats.com
Old Oct 23, 2003 | 05:13 PM
MAX2000JP's Avatar
My brother has a 1997 M3 5 speed with ECIS intake, Koni/GC, and AAW clutch/flywheel. It's faster than any Maxima I have driven. IMO it would take F/I in a Maxi to take his car out.
Old Oct 23, 2003 | 05:24 PM
nellynel's Avatar
I used to own a 95 M3. I actually raced a 2K2 Max with it. I did own the Max but I was impressed with the way it hung on. That is why I own a Max now. I do miss the bimmer though.
Old Oct 23, 2003 | 05:33 PM
jgibson146's Avatar
Go to www.car-stats.com for all your 0-60 times and so on. Good web site.
http://car-stats.com/stats/showstats...tsgivenid.aspx
Old Oct 23, 2003 | 06:05 PM
F23A4's Avatar
Here's a snippet from Car and Driver (July 1994)
0-60: 5.6 seconds
0-100: 14.9 seconds
1/4 mile: 14.3 sec @ 98 mph
Top speed: 137mph (GOVERNED)
handling: .86g
70-0 braking: 158ft
For that time (1994), it was pretty impressive.
James92SE
142
Jan 2, 2024 09:23 AM
halfpol
Oct 17, 2022 12:16 PM
Finkle
Sep 27, 2015 09:53 PM
Maxie40
Sep 14, 2015 11:28 AM
stromm
Aug 27, 2015 04:13 PM
