Breaking Engine on purpose?
This is all IF ok guys
I know these dope guys at this Performance shop.
My car is still underwarranty, and have an EXT B2B Warranty too, But If I were to break my engine, the VQ30DE, Theoretically I could get it replaced with the VQ30DE-k for free right? Both the motors should cost the same right?
i was planning on doing my warranty claim at a shop, not the Stealership, These guys dont car If I got AM parts. Its called MPH Motor Sports, They do performance parts installs and stock installs, This guy from cali is gettin his RB installed for his 240 S14 overthere, So many Honda swap installs too.
So does anyone know if its possible?
Nice. Illegal activities. Nice.
Holy crap. It's ILLEGAL to purposely DECEIVE the warranty holder. Holy crap.
Hey it was Theoretical ok. And how is it illegle to brake your engine, And Jeff how come you always have to put me down?
I doubt that they would replace your motor. I know it's true elsewhere, and probably is here, but you can usually spot what caused the problem by looking at the problem itself. Filing a warranty claim for a replacement motor and all the work done to get it fixed would cost a lot. There is slim chance that you would get everything for free, just because you have a warranty.
But good luck on your adventure. Have fun trying to break the VQ though. You sure picked the wrong motor to try and "break".
arg.
1. Nissan of North America or your warrenter has the final say for if your claim will be accepted or denied. They generally dont hire out the work either, esp. not to a shop of your choice.
2. They will not replace it with a VQ30DE-K, and even if they were to, do you even know if its a direct replacement? (no.) You will most likely get a low mileage junk yard engine, or one from a dealership.
3. If you spin a bearing, you can replace it. Your source is incorrect. I've driven an engine that had 3 spun rod bearings.
4. Go ahead, try to break your engine. The only way you will be able to (stock) is run it on the highway in 2nd gear for a few hours (even then these engines are built pretty dang well). Dont even think about running it without oil or putting sand or something in the engine. It is easy to see when this happens, and you will most likely be declined the warrenty because of abnormal driving conditions, esp. when they turn the motor over and the oil pump works perfectly, and measures within factory specs.
Your best bet is to give up on this idea.
shilov
Feb 19, 2024 09:40 PM
jchronis2552
Sep 21, 2015 05:52 AM
lowpost99
Sep 8, 2015 05:06 AM
