Question for 02'-03' GLE Owners Still on EL42's
For those of you fellow 02' & 03' GLE owners still on the OEM 215/55-15 EL42's, question on preferred air pressure. It will be 2 to 6 weeks before I get my Michelin Pilot Sport A/S's on due to my travel schedule and I need to put about 800-1000 miles on the Turanza's in the next 2 weeks. Since installing the Stillen RSB and OTTO FSTB 2 weeks ago I have been experimenting with tire pressures ranging from 39 psi down to the OEM spec. of 32 psi (max is 44 psi) to feel the impact on handling & ride quality with this setup. As of today I am back at 32 psi as it seems to provide the best ride. What specific pressures are you fellas runnin' if different and why? Thanks in advance.
Always go with the OEM spec. The 'max psi' is determined by the tire manufacturer for the tire itself. Another vehicle with the same tire may have a higher OEM spec. As you already determined, the 32 psi works best. Keep it there.
Heh heh - Thanks as always Blue!
Did you get your Max waxed last weekend?
Hey, one more post and you won't be a noob anymore!!
Mar 12, 2020 12:06 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
