ecu problem :(
Old Nov 13, 2003 | 11:24 PM
Maxpower96's Avatar
ecu problem :(
Hi guys
well my "check engine " light is on so i wanted to check 4 the codes. I went to www.vbxmaxima.8m.com/ecu.html to get the procedures.
So here is the problem. I removed the panel then pierced the plastic shield but couldn't see the screw-thingy. I said to myself that maybe it was deeper in the hole so i pushed my flathead screwdriver until it hit something and turned it slowly hoping that it would fall into the screw's socket. But it feels as though there was like a flat surface. I couldn't "feel" the screw inside. Is it normal???
hopefully u guys can help me on this. I don't feel like bringing my car to the dealer and pay them just to check what the codes are.
Any info would really help thanks.
Chuyen.
Old Nov 13, 2003 | 11:35 PM
mchne's Avatar
you should be able to see the screw, plain as day.
at least I know I can... same year car as yours.
Old Nov 14, 2003 | 05:27 AM
big_al's Avatar
Use a flashlight and stick your head under there and look. the screw is about an 1/8" deep, you can definitely see it.
Old Nov 14, 2003 | 06:18 AM
gonzo's Avatar
if you pull the plastic panel off, the ecu is directly behind it. it just looks like a metal box. the diagnosis screw is on the left side, which means its towards the engine bay.
does that make sense? its really right in front of you.
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
mix master
Sep 4, 2015 05:50 PM
