Installing light bulbs
Old Nov 17, 2003 | 01:27 PM
lhh77's Avatar
Hi, I misplaced my manual and are having trouble replacing my burned out low beam 9003/H3 light bulb.
Can someone tell me how to remove and install the lights? Unlike other cars where you can push in and twist off, I can't seem to nudge mine.
2000 Maxima SE.
Thanks.
Old Nov 17, 2003 | 01:44 PM
Igor911's Avatar
2000 Maxima SE.
Thanks.
First of all its H4 bulb.
You bought the wrong bulb. H4 is dual beam low/high.
Take the connector off, then pull off the rubber surrounding. Then there is a Y clip. Push it in togather and pull it off. Slide out the bulb and reverse the process to take it out to put it back in.
Old Nov 17, 2003 | 01:45 PM
NYC TAR's Avatar
spray some 40d-w around the seal or **** it might have been stuck, But, care full and not to get inside the light case or the new bulb. I have notice that there are alot of blow bulb out there like 2 out of 10 cars I see why -esp in NYC? is it because it from the cold weather.
Old Nov 17, 2003 | 02:21 PM
lhh77's Avatar
Thanks but...
The problem is, I can't even budge the connector. I actually broke off a bit of the plastic casing (lots of grease comes out).
How do you pull it off? Push in and turn? Or just PULL.
Can't they do it like other cars? Like Toyota? Where you just push in and twist? And then pull? Thanks for your help though. I guess I'll return the bulbs and buy new ones.
Old Nov 17, 2003 | 03:16 PM
Igor911's Avatar
You push on the sides on the connector, push the sides in and pull off. Very easy.
KristyKarina
Aug 23, 2015 09:53 AM
220k+ A32
Aug 17, 2015 03:57 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
MikesChevelle
Aug 6, 2015 11:36 AM
