Erasers in motor mounts!
Old Nov 23, 2003 | 07:35 PM
PoePoe2797's Avatar
I heard that you can use erasers in your motor mounts as an alternative to polyurethaning them. It sounds like it could work by shoving them into the spaces. Any one else have any opinions on this? I'm willing to try this if someone tells me how exactly to take the mounts off
Old Nov 23, 2003 | 09:05 PM
PoePoe2797's Avatar
TTT....someone has to have opinions and/or instructions on how to remove them
Old Nov 23, 2003 | 09:42 PM
Chunger's Avatar
My other car is a Hybrid
The rubber hose technique also works... 3 years and counting... They just wedge in there...
Old Nov 23, 2003 | 09:53 PM
nismos14's Avatar
§è~® f®ÈÄk
hmm got pics of this?
Old Nov 23, 2003 | 11:03 PM
nick's Avatar
hmmmm - interesting , sounds like next project
more info would be nice
Nick
Old Nov 24, 2003 | 08:25 AM
ABK's Avatar
ABK
The easiest way to make engine mounts stiff take them off and fill them with window sealer (this black nasty ****). Makes them alot better.
Old Nov 24, 2003 | 09:04 AM
PoePoe2797's Avatar
Yea but you have to wait for them to dry.
BTW, anyone know how to take mounts off?
Old Nov 24, 2003 | 10:44 AM
Stephen Max's Avatar
1. support engine (although I've done it without supporting the engine)
2. remove bolts
Old Nov 24, 2003 | 10:50 AM
PoePoe2797's Avatar
Ok, well I purchased a 6 pack of erasers today. Heres the story, basically I WD-40'd and wedged them into the mounts. I did just the tranny and the front mount. 3 in the tranny and 2 in the front. I did not take the mount off because there was enough clearance for the erasers to slip into.
My Impression: WOW! It is a new car, seriously...it makes that big of a difference and thats only with 2 mounts done. I'm still gunna to the rear and side tommorow. This was VERY simple because all I had to do was lub them up and slip them in the holes. No removal necessary
Old Nov 24, 2003 | 01:49 PM
my99maxisnice's Avatar
What does this do?
Old Nov 24, 2003 | 02:05 PM
USRacer900's Avatar
Yeah, I'm curious also. Does it make that transmission shifts seem smoother?
Old Nov 24, 2003 | 02:07 PM
MAXSRB's Avatar
LOL, that is funny as hell although amazing at the same time. If the erasers make that big of a difference that would be the best mod for the money.
I cant believe im hearing this cause my number one peeve about the max was clutch chatter and i was actually thinking about getting new mounts and filling them with polyurethane. Too bad i have to sell the max (stupid insurance)
Old Nov 24, 2003 | 03:15 PM
pjalst
What does the mounts do? I'm only asking cause the search is not working
Old Nov 24, 2003 | 03:28 PM
Kolyan's Avatar
http://forums.maxima.org/showthread.php?t=265331
Old Nov 24, 2003 | 04:22 PM
WhtmaxRcr's Avatar
Anyone try this on a manual transmission, or would it make no dfference auto or stick?
Old Nov 24, 2003 | 06:22 PM
PoePoe2797's Avatar
I have a 5 speed. My results are that there is a lot less play in the tranny and engine. It's still a little rougher than normal but with only 2 mounts done it made a big difference. I think the one that makes the biggest difference is the rear mount which I will do tommorow. I'm telling you, it may sound stupid or cheap but it works, and I didn't even have to take the mounts out
Old Nov 24, 2003 | 07:33 PM
MaximaVQ97's Avatar
anyone got pics or a write up??
thanks
-anthony
Old Nov 24, 2003 | 07:40 PM
PoePoe2797's Avatar
Read my posts, I said all I did was buy a multipack of erasers, sprayed them with WD-40 and sliped them in the visible opening on the mounts. Nothing has to be removed. With the WD-40 they just slide right in through the openings. For the front and rear, you have to slide them in diagnally but the tranny theres nothing blocking the hole so they slide in normally. I used 3 perpendicular (meaning directly into) on the tranny, and 2 parallel (meaning sideways) in the front. Take a look at your mounts and youll see what I mean
Old Nov 24, 2003 | 07:43 PM
MaximaEvolution's Avatar
how big were the erasers that you bought?
1991tsi's Avatar
what shape are the erasers you're using?
Old Nov 24, 2003 | 08:29 PM
PoePoe2797's Avatar
Old Nov 24, 2003 | 09:50 PM
silvermax2k2's Avatar
this is soo funny.... it is hard for me to belive that this actually works... i may have to try this tomorrow... lol.... pink erasers.... too funny... but i guess i can not knock it till i try it. thanks for the tip, and i will give results after a few hours for driving!
Chris
Old Nov 24, 2003 | 10:02 PM
nismos14's Avatar
§è~® f®ÈÄk
i guess this will be the next big mod
Old Nov 24, 2003 | 10:09 PM
Ramses718's Avatar
I think I'm gonna try this tomorrow. This sounds goldennnnnn lol.
Old Nov 24, 2003 | 10:14 PM
MaxSE99's Avatar
Sounds great, I will definatly try it, but I only have one possible problem with the idea.....Erasers are meant to erode with friction, so after time they will rock around, weardown and fall out....Its just a guess but for only a small price its worth trying.
Old Nov 24, 2003 | 10:27 PM
joaquink's Avatar
¿Hablas Español?
OMG, you all can't be serious. We're talking about $10-$15 worth of 3M window sealer to do this right or a bit more if you're going to try the polyurethane. Why not just do it once and do it right? You can get all 4 mounts out in well under an hour. Fill them up and put them in the next morning before taking off again.
Old Nov 25, 2003 | 01:29 PM
PoePoe2797's Avatar
So did anyone else try this yet besides me?
Old Nov 25, 2003 | 01:44 PM
MaxSE99's Avatar
I will in the spring when I get her out of storage, Pennsylvania winters SUCK!!
Old Nov 25, 2003 | 02:11 PM
Ramses718's Avatar
Man you are my hero. I just got home from driving around with my new eraser mounts. The feel is so much different. Not that much rocking anymore in first. I LOVE YOU lol. Saved me a few hundred dollars on mounts and labor. Eventually I'mma have to change the mounts though but for in the mean time this is good enough for me.
Old Nov 25, 2003 | 02:21 PM
waveridr85's Avatar
how will this due on an auto? is there an easy way to get them out if i dont liek them?
Old Nov 25, 2003 | 02:34 PM
Shadow's Avatar
Has anyone thought about the durability issues of erasers? How long do you think that they're going to stand up to the rocking motion of the motor before they start disintegrating? People tear through factory motor mounts and they're designed for this usage, how long are cheap erasers going to last? And the WD-40 sprayed on there probably isn't helping the life of the eraser either. That plus the heat under the engine and a multitude of other things. If this works for more than 2 weeks before you start spewing chunks of eraser from the mounts, I'll be really surprised.
You have to go under the car anyways, like joaquink said, why not just spend the extra time and a few bucks and do it right.
Old Nov 25, 2003 | 02:40 PM
Kevlo911's Avatar
Kevlo for President
if i spayed silicone lubricant in hte motor mounts, would it help any or would it hurt the 7 year old motor mounts?
Old Nov 25, 2003 | 02:44 PM
PoePoe2797's Avatar
Honestly...I bought a 6pack of erasers for $2.00. What am i losing? Even if they don't last too long, who cares? Ill just buy new ones and shove those in. I think it will last because with the eraser shoved in, theres gunna be no rubbing, just squeezing. It's not too different from polyurethaning them and is way cheaper. I think everyone shoulf give this a try, anyone can do it and all you have to buy is erasers.
Don't knock it till you try it... you may be surprised!
Old Nov 25, 2003 | 02:58 PM
Ramses718's Avatar
Bro after you put them in the only way to go is up. If your motor mounts are that bad that you consider sticking pink erasers in them then you'll be happy with the results. I have a 5 speed. I only have three mounts so I dont need to get under the car. I just got under the hood, sprayed a whole bunch of wd40 and just started shoving the little ****s in. I prob should have also squirted some silicone in there too. I think that would make the erasers more durable and less prone to wear. I think this is a great mod for the buck if not the best lolol
Old Nov 25, 2003 | 02:59 PM
Shadow's Avatar
If you squeeze erasers enough, they will still fail and lose elasticity. My only point is that even at $2.00 each time, that will quickly add up to the $10 or so you'd spend on polyurethane and you'd only have to do that once so you wouldn't be crawling under your car constantly.
I got a real good deal on some PR motor mounts. But I'd definitely like to see how long this works for.
Old Nov 25, 2003 | 07:18 PM
PoePoe2797's Avatar
I see what you saying, but that also applies to polyurethane somewhat...they can lose elasticity also and start to weaken and possibly crack. This is just to create temporary relief of engine flop. It's not going to last forever but it'll do for now.
About removal: To remove them, just squirt a little WD-40 in the motor mount, and use a wire hanger to fish out the eraser.
Old Nov 26, 2003 | 02:07 AM
pjalst
any one have pics of where to find the motor mounts?
Old Nov 26, 2003 | 09:07 AM
PoePoe2797's Avatar
I just took this from my program, its pretty decent about showing you where to look. Cardomain made picture a lot smaller when I uploaded it but you get the idea.
Old Sep 28, 2004 | 05:20 PM
michaelnyden's Avatar
I bought those standard pink wedge type erasors at staples, but couldn't get any of them in my mounts....any pics? where in the mounts and how should I be shoving them in?
Old Sep 28, 2004 | 09:01 PM
Nismo3112's Avatar
Custom User Title
Bump 132456
