keyless entry: somehow making a siren "chirp" on lock/unlock
Jon,
Actually, I have a diagram that shows how you could add that to ANY existing system. I'll look around to see if I can find it. If not, I'll try to give it to you from memory. If I CAN find the diagram, I could fax it to you, or I'll just try to explain it to you as best as I can.
Originally posted by nubiannupe
Jon,
Jon,
d.e.i.
You probally have the dei which is a viper sold under a cheap name,if so you can hook the siren up to the remote start, it is 2 wires and you connect it into your acc. spot on the brain which is ushually tucked under the dash near your hood latch, if this is a non dei or viper, most likely it is simmilar,also ushuall mounting space is behind the master cylender on the fire wall( ps i recomend you relocate the alarm to a place where you can't just reach under and pull it out, this will disable the starter but not a thiefs ability to rob that ***
